Question about Sony MDR-NC40 Consumer Headphones
How do I open up the earphone to refasten the mounting screw
1. Carefully remove the ear pad.
2. There is a shiny plastic cover over the speaker with some foam padding. Gently pry this off - it is sticky.
3. You will now see the speaker holder - it is round and has 4 slots. If you gently rotate it anti clockwise it can be removed, releasing the speaker.
4. Under the speaker is a small round plastic sticker, this protects the back of the speaker from the screw - remove it.
5. You will now see the screw head - cross head screw - tighten it back onto the headpiece and re-assemble all components.
Posted on Aug 19, 2011
  • Enrique C
    Enrique C Feb 05, 2015
    Many thanks! I followed your instructions and it worked pretty well.
Akai ewi 4000s neck strap mount
1 Un screw all the screw on black panel, but must remember where each on goes, but Be careful not the two screws in side mouth pice which holding the pitch bend unit. 2. open the battery cover remove all the battery 3. Remove the 1/4 earphone nut, and all screws on the silver metal case. (Under the black plastic ), you don't need to remove any screws from the "key" side 4. Use something to pull the battery Cartridge sideway out from Main attachments, but not all the way out from the ewi case, because you can't, the plastic case structure will be in the way, 5. Use some flat pice metal like dinning knife insert in to between black and sliver metal to separate the two parts, start from the mouth pice end, once you open wide enough the battery cartridge can be remove from the case out. Now you can open the Ewi 4000s and see the two HX nuts that holds the strap mount, put some Nail polish on it before you tie them up.....Warning.. You must pull the battery cartage sideway out from its electric plugging mount before you are trying to separate the plastic and silver housing otherwise you will damage the circuit board. That was What I did to mine. Good luck and may God provide you wisdom for this.
Apr 22, 2013 | Akai Ewi4000s Electronic Wind Instrument
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
How to replace light bulbs in a Jerdon Tri-fold makeup mirror
In order to replace bulbs, look at the back of the mirror. There will be four white circle coverings hiding the screw heads, and these must be drilled open in order to access the screws that hold the two halves of the mirror together (these coverings will not have to be replaced). Once these screws are located and unscrewed, flip the mirror back over and remove the top half. Carefully, replace the bulbs.
Oct 25, 2011 | Cars & Trucks
Paper jam
Hi. This could be sendor is failing or there is a jammed paper on you printer.
How to removed jammed paper
1.Unplug all cables (USB and power)
2.Turn around the printer
3.In the back there should be a small door that on my printer (SCX-4300) flips upside.
4.Look for any jammed paper.
5.Pull out the jammed paper.
Here's how to fix the sensor
Unplug everything from the back and then remove the four screws from the back panel. Pull the panel out but watch that the on/off switch doesn't hang the cover up.Once off, I removed the screw from the mount holding the right end of the sensor stick while holding the mount in place with my finger. When the screw is out, lift the mount up and carefully slide it off of the stick. Carefully rotate the spring, topside away until the left side of the spring catches the sensor piece. Now rotate the other end of the spring once more around the stick and while holding it at the top of the stick (12 o'clock) slide the mount back on. With the mount in place, release the spring and it will come to rest on the mount. Refasten the mount and check for light tension on the sensor. If it pushes forward when you release it, you're good to go. Refasten the back panel, attach all wires and enjoy.
Have a good one!
Jul 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
HOW TO REPLACE STOP LIGHT BULB ON 1999 FORD ESCORT WAGON
Open your trunk or hatch,you may have to pull back the carpet that will cover the tailight lens mounts on the inside.There are 3-or 4 plastic wing nut style nuts behind the light in the trunk. remove these,and pull the lens out from the outside. the lighs will turn usually counter clockwise. replace burnt bulbs. replace the lens,and refasten the nuts carefully.
Feb 14, 2010 | 1999 Ford Escort
Replaced the throttle position sensor and now have a high idle
it needs to be adjusted check the mounting holes they are slotted, turn the tps and refasten at low idle 750 rpms
Jan 17, 2010 | 2007 Chevrolet Silverado 1500 2WD
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 19, 2009 | Garmin GPS
LG Refrigerator LFX25960ST Dispenser Panel
Here are four ways to reattach the panel:
- Put a short stainless steel screw in each of the two lower corners of the panel. Drill a hole in the panel first -- the hole should be bigger than the diameter of the screw. Next, with the panel in place, carefully drill thru these holes, into the door, a hole smaller than the diameter of the screw. Then screw the panel back on.
- Or, put thick double stick tape along the bottom of the opening for the panel. Two short pieces would be preferable -- this would make it easier to remove.
- Or, if there is enough PVC in the plastic panel, PVC pipe solvent may allow you to refasten the broken clips to the panel. (This is available at hardware stores -- you may want to use PVC primer as well -- but be very careful, the primer is purple, very "thin", and will run -- it will stain everything it touches. If the panel is not PVC, this solution will not work.
- Or, 5-minute epoxy may hold the broken clips to the panel (make sure the epoxy is thouroughly mixed).
Apr 23, 2009 | LG Refrigerators
Sound out of one earphone only even though the earphones are ok
socket might be faulty and not that easy as any other part to procure cause its board mounted one ask some one to open and set it right if its not brocken the contact legs
Jan 28, 2009 | Sony NW-A1000 MP3 Player
Sony MDR-NC40 Consumer Headphones Logo
779 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
