Can I get this model controller on line and print out?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
What board is it first then go to web site look it up then download it to a mem stick put it in thats all jim
Posted on Apr 05, 2011
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Can't print checks printer not activated code30
Let me know the printer model and make, its type etc.
Also about the operating system.. is the error message displaying on PC or Printer??
Oct 21, 2008 | Office Equipment & Supplies
Do i need a eol resistor for a fire bell on a three zone fire alarm controll pannel
Usually, No. Any sounder (or strobe) is a warning device, and not a sensor.
EOL resistors are to prevent tampering on sensor lines.
To date I've only found one system that actively monitors the sounder line to determine the presence of a load.
Usually, a printed installation diagram is included inside the control panel to indicate EOL requiremants. Failing this, Google for an installation manual for the specific model of control panel (indicated on the main printed circuit board).
Apr 23, 2011 | Hardware & Accessories
In Hp officejet 6110, when i am printing then it come dark and lining is coming plus to print its take long time. need soluation.
Your printer head must be dirty and needs to be cleaned. Try going to your printer application and look for the option for maintenance. If you cant find it, you can go to control panel, printers and faxes, then double click on your printer model. It should take you to your printers menu, just look for the option to clean it. Print a test page after cleaning. If you still see lines, just repeatedly do the cleaning until you no longer see the lines. If it still doesn't work, you can contact HP.
Apr 05, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Whirlpool oven controls not working, oven will not come on, it does have power. Just keypad not lighting up and won't run oven.
Research on line the model number for a service manual. The control PC bd or key bd is the problem.
(PC-printed circuit, bd-board). Best Wishes
May 12, 2010 | Ovens
Fine, black, horizontal lines when printing photos- a very recent problem. Canon Pixma 750
you may have a hardware problem: either a Defective laser scanner assembly or an failing engine controller board, also the where the lines appear may also indicate at that point of the printing process, therefore what component, the defect appears. unfortunately this may vary from model to model even within a brand.
Repetitive defects are almost always caused by the toner cartridge or fusing assembly, and occasionally the transfer roller. you may have to replace a few components, one at a time and test.
try resetting the connectors on the laser scanner and engine controller board.
also try to replace the laser/scanner assembly followed by the engine controller board, if necessary
Apr 04, 2010 | Canon Office Equipment & Supplies
Looking for a vacum line diagram so i can print it 1996 gmc jimmy
GMC S10/S15/Sonoma Pick-Ups 1982-1993 Repair Manual
VACUUM DIAGRAMS (See Figures 1 through 85)
Below is a listing of vacuum diagrams for most of the engine and emissions package combinations covered by this manual. Because vacuum circuits will vary based on various engine and vehicle options, always refer first to the vehicle emission control information label, if present. Should the label be missing, or should vehicle be equipped with a different engine from the car's original equipment, refer to the diagrams below for the same or similar configuration.
Check the link autozone.com (free register), select the year ('91 sample), Brand, Model, Sub-Model, Engine Size and make the next root...
1991 GMC TRUCK S15 4WD 4.3L TBI 6CYL REPAIR GUIDE >> EMISSION CONTROLS >> VACUUM DIAGRAMS
I really hope helps with this (remember rated this help). Good luck.
Jan 07, 2010 | GMC S-15 Cars & Trucks
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
