Question about Power Acoustik Gothic OV2-820 Car Audio Amplifier
I have a Power Akoustic OV2-820 w Gothic Serious amp hooked up to two 12-inch Kicker Competition CRV subwoofers in my 1998 Jeep Grand Cherokee. When I hooked my system up a few days ago, everything was working fine. The blue light on the top of my amp was on, and the green power light on the side of my amp was on. Sometime throughout the day, my system stopped working. I couldn't tell you when because my volume was down. Now, when I turn my car on the red protect light on the side of my amp will come on for 3 seconds and then turn off. The blue light is no longer on either. I haven't changed any wiring whatsoever. Any assistance would be greatly appreciated.
5 Suggested Answers
brandonboyce
  • 84 Answers
SOURCE: no power to amp
you probably blew it up.
Posted on Jun 19, 2007
  • 631 Answers
SOURCE: Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Nov 30, 2007
  • 631 Answers
SOURCE: Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Posted on Sep 21, 2008
  • 30 Answers
SOURCE: power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Posted on Aug 19, 2009
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do you install a 10 inch kicker with a built in amp
Rum a fused power line to the Battery, a fused remove on from the head unit or keyed fuse in the fuse box, ground it to the chassis, hook up the signal source using speaker wires or pre-amp cables. Bolt it down so it wont more while driving
Dec 28, 2013 | Kicker Car Audio & Video
Why does my amp turn off when i hook up my 12 inch kicker
Possibly due to a poor battery, you could try installing a power cap to prevent the amp shutting down/protect due to low voltage when the starter kicks in.
May 10, 2012 | Kicker 07CVT124 12 inch ShallowMount...
Will I able to run two or four kicker competition fifteen inch subs to this amp?
  • You could effectively hook up two 15" Kickers. Make sure they are power hungry because that amp has some weight behind it. I don't recommend 4 speakers though. Get a second amp if you want to run 4 15" speakers.
  • Thanks for using FixYa
Regards, Tony
Jun 23, 2011 | Hifonics BXI2008D Car Amp
Factory radio in 2010 honda crv
You will have to pull out the head unit and see if there is a blue remote wire for am and rca audio output jacks that go to amp. I highly doubt it. Usually you have to get an aftermarket deck
Jul 27, 2010 | Kicker Car Audio & Video
Will this amp power two 12" subs?
Yes. The Kicker xs50 competition amp will l ! Pushs my old school autobahn aw1206t's very nicely and beats my 2 sundown sa15's senseless. Wire down to 1 ohm and bridge. People may say yeah rite. Ok. Thats ok.
Dec 07, 2009 | Kicker XS50 Car Audio Amplifier
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Bridging to 12 inch kicker competition subs to my 1000 watt alpine 4 channel amp
I'm a bit confused. For Alpine amps, the "M" prefix is for monoblock (aka single channel) amps and the "F" prefix is for multichannel amps. The only M550 I find is an MRD-M550, which is a monoblock, not a 4 channel like you say.
Unfortunately, I can't give you accurate help until we know weather it's truly 1 channel or 4 channel. Then I'll be glad to help!
Mar 05, 2008 | Kicker 01C8VR4 Car Subwoofer
Power Acoustik Gothic OV2-820 Car Audio Amplifier Logo
99 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
