Question about HP LaserJet P2015dn Printer
Dear sir, My paper tray has jammed and not able to move in. Please advise how to clear
  • HP Master
  • 1,915 Answers
Sounds like your duplex tray is in the down position. Remove the tray and look inside. You will see a metal tray with a plastic edge and a green section, push this back up into the printer until it locks in place.
Posted on Apr 05, 2011
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Please advise what you charge for solving following problem:\r\n"Paper jam on Brother MFC-260C:Following Brother User's Guide, I removed the Jam Clear Cover, and pulled out jammed paper, but got only...
1. Unplug machines power cord from the power outlet. 2. Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position. 4c89ecbe03c0173ae1000000cd8620c6.gif 3. Remove all of the paper scraps stuck inside the machine. NOTE: The print head can be moved manually with hand to assist with removing all of the paper scraps. 4c89ed1103c0173ae1000000cd8620c6.gif
4. Turn the machine around and open the Jam Clear Cover (1). Look inside the machine and remove any jammed paper. Then close the Jam Clear Cover (1).
5. After removing all of the paper scraps, Close the scanner cover by lifting the scanner cover to release the lock. Gently push the green scanner cover support down and then close the cover.
6. Remove the paper tray from the machine.
7. Place one of your hands under the LCD unit and into the opening of where the paper tray was.
8. Using your hand, lift the front of the machine approximately 6 inches off the surface.
9. Look inside the tray areas roof of the machine and you should see a row of black rollers. See picture below.
10. Look in-between each of the black rollers for a piece of stuck scrap paper. (A flash light may need to be used if you are having trouble locating the paper scrap).
11. Using a pair of tweezers, the paper scrap can be easily removed from the exit rollers.
12. Place the machine gently down onto the surface.
- If paper scraps were found and removed from the machine, continue to STEP 13.
- If no paper scraps were found inside the machine, the paper in the tray may be causing the issue. If the paper is slightly curled, the print head will catch the edge of the paper and tear it. To resolve the issue, the paper must be replaced.
- If you do not have replacement paper, follow the rest of this solution, after you have replaced the paper.
- If you replaced the paper, continue to STEP 13.
13. Put the paper tray back into the machine.
Dec 18, 2010 | Brother Office Equipment & Supplies
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
How to clear a paper jam you can't see
Dear SIr,
plzz folow this step,
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Thanks For Your Time
    Apr 10, 2010 | Dell 924 All-in-One InkJet Printer
    Paper jam
    Dear sir,
    i am giving u setp to solved your problem,
    Step one: Remove any loose paper.
    Step two: Clear the jam from the back of the All-in-One
    Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
    Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Have cleared paper jam, but alarm light remains on. there is no paper jammed anywhere. please advise
    1. Close the tray deck properly.
    2. Hold the print key for a moment ...approx 5 secs...it will solve the problem or else restart it.
    Oct 19, 2009 | Canon Pixma MP450 All-In-One InkJet...
    Paper jam and still won't print
    Hi
    Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
    Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
    2. Pull out the jammed paper.
    3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
    4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
    5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
    6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
    Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
    8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Aug 15, 2009 | Brother Office Equipment & Supplies
    Jamming
    Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
    Jul 20, 2009 | Ricoh Aficio MP1600SPF Copier
    HP LaserJet P2015dn Printer Logo
    64 people viewed this question
    Seeker5211
    Seeker5211
