Question about NetGear WNR2000 Wireless Router
I have the WNR2000v3 router and my panasonic blue ray is not getting an IP address. My lap top works fine. I am hardlined to blu-ray.
  • 3 more comments
  • Tony Apr 05, 2011
    did you set your blue ray to obtain IP address?
    does the cat 5 cable work with other devices?
  • Bert Cutting Apr 05, 2011
    It gives me a message about failing to find an IP. The cable works on my lap top but not the blu-ray.
  • Tony Apr 05, 2011
    model # for your blu ray?
    Model: Panasonic DMP-BD65
    If I plug the Ethernet from the cable modem directly to the Blu-ray, it works fine.
  • Bert Cutting May 08, 2011
    I have since found out that Netgear blocks blu-rays so I had to switch to a Cisco router. Luckily I found this out before 30 days so Best Buy let me switch it out.
Same combo...Finally figured out that I had to manually input Default gateway and IP addresses. But, I also have the same problem with the Mits TV I bought the same time as my BD player. After a lot of looking, I've decided the router is the main culprit and it's time to buy a new one to keep what little hair I have left.
Posted on Jul 06, 2011
How do I reconnect my Panasonic Bluetooth to Netflix? It suddenly stopped working and we are paying for Netflix but not getting it
Restart your router (pull power for 10 secs and replace). Wait for the router to reset and reconnect. I have found that internet connections to devices often have difficulties reconnecting from time to time. It may be the issue of automatically assigning IP addresses?
Oct 15, 2014 | Panasonic 3d Blu-ray Dvd Player Dmp-bdt210...
I have a Vizio VBR120 Blu-ray player and it won't connect to my internet using my NETGEAR WNR2000v3 Router. I have tried using an ethernet cable from router to the blu-ray player. I will not find an IP...
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Mar 05, 2011 | Vizio VBR210 Blu-Ray Player
Im having trouble connecting my blu ray player with my belkin router. Netflix does not work
BLU RAY :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the BLU RAY
Step 7: Get the IP Address of the BLU RAY
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the BLU RAY in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Nov 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
Apr 25, 2010 | Computers & Internet
My Samsung Blue Ray Disc player with a Samsung WIS09ABGN LAN adapter won't connect with my Apple Express WiFi and MacBook Pro. How do I make it work?
This disc player is get an IP address.
1) If connected to MacBook Pro with an ethernet cable, it will get an IP address something like 169.254.xx.xx but it will communicate with the laptop
2) If connected the Blu-ray disc player using Apple Express, you need to create an Ad-Hoc wireless network to share media and stream it.
**But ensure that the in-built firewall on a MAC is completely turned OFF or else it should be properly configured.
Jan 14, 2010 | Computers & Internet
My Blu-Ray player won't launch the internet/netflix while plugged in with the ethernet cord. When a computer is plugged in it finds internet access but the Blu-Ray player will not connect to the internet....
When you connect the computer to the router, it works !.
When you connect the Player to the router, it doesn't work.
That means the router is working fine.
You will need to check the settings on the Player.
Check the IP address of the Player.
Are you getting the correct IP address on the Player.
You should get the private IP address on the Player.
First check the settings on the router.
Click Here to know more about routers
Oct 28, 2009 | 2wire 1800HG Router (RG1800HG00)
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
NetGear WNR2000 Wireless Router Logo
512 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
