Phow do you use an rf scanner I have used them before but i just want to know how to enter all the info when operating one
Rf switch input
use the sorce button lol
Jan 25, 2014 | Westinghouse Televison & Video
Why does my moonraker cb change channels by itself.
This can be caused by RF feedback. RF is radio frequency energy - the same energy that your transmitter puts out onto the coax cable & antenna.
RF feedback is similar to audio feedback in that some of the output re-enters the circuit in a place it doesn't belong or is designed. RF feedback is a direct result of a poorly matched antenna system as shown by an SWR meter. A standing wave ratio or "SWR" of 2.0:1 - 2:5.1 (read this as: two point zero to one and two point five to one) or greater is generally accepted as the worst SWR a transmitter can tolerate - but also requires lowering RF power (wattage) to continue transmitting.
Some common sources of high SWR are: 1) wrong cable type (usually a 50 ohm cable is used), 2) damaged cable, 3) untuned antenna, 4) damaged previously tuned antenna, etc. The SWR of an antenna system should be checked and adjusted as needed to assure maximum power transfer to the antenna. If the system has a high SWR, the antenna reflects some of the RF energy back on the coax - into the radio. The effects can be tingles / burns on the lips - if using a mic with a metal guard, noise, and erratic operation of some rig settings. This energy is unexpected and can cause all sorts of strange radio operations and is not an uncommon occurrence in a situation such as this.
You can correct this problem by purchasing or borrowing an SWR meter or bridge designed to work in the range of frequencies that your CB uses. Follow the directions included to lengthen or shorten antenna elements as needed. An ideal SWR is 1.1:1. Generally, any value of SWR less than 1.5:1 is considered very good. A check of SWR on the low, mid and highest frequencies will give you an idea as to how well the antenna works on the frequencies you use, and let you know which frequencies you should avoid.
Apr 21, 2012 | Radio Communications
How can i program my scanner i've got the codes but dont know how to program it
To enter a known frequency (they're not codes) into your scanner:
- Power the unit ON
- Press the MANUAL key
- Enter a channel number (01 - 30)
- Press MANUAL
- Enter the frequency, including decimal point (e.g., 438.065)
- Press E
More detailed programming is outlined in the scanner operating instructions, which you can download and print here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jul 25, 2010 | Uniden BC60XLT-1 Handheld Scanner
Re-set key on the Motorolla MC9090 RF Scanner
Take out the battery, press and hold the power button and trigger for 30 sec and push back the battery the release the buttons.
Jun 30, 2010 | Zebra Symbol Technologies MC909X-G Series...
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
2. Use the number keys and to enter the frequency (including the decimal point) you want to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency.
• The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475.
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
Programming a pro 137 scanner
1. Press SCAN/MAN to enter manual mode.
2. Press EPGM to put the scanner in
programming mode. PGM appears.
3. Use the number keys to enter the channel
number you want to assign to a frequency.
4. Press SCAN.
5. Use the number keys and •CLR to enter the
frequency, including the decimal point you
want to store.
6. Press EPGM to store the frequency.
7. Press EPGM again. The Edit Channel menu
appears.
8. Rotate the knob to select 1: Edit Car#, then
press EPGM.
9. Use the number keys to enter the car number
in 3-digits, then press EPGM.
10. Rotate the knob to select 2: Edit Tag, then press
EPGM.
11. Use the number keys to enter the tag then
press EPGM.
12. To program the next channel in sequence,
press Menu then repeat the steps from 3.
For more details, you can download and print the complete operating manual by following this link:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000137_PM_EN.pdf
To be certain that you have all the active frequencies in your area, visit:
Dec 28, 2009 | Radio Shack Pro-97 Handheld Scanner
How to use an RF scanner? I have never used one of these devices and I need to learn how to use one for my job assisgment.
you are on the wrong site. you need to find out what kind of RF scanner you will be working with and find the tutorial for that device on the mannufacruer's website. If you for some reason can't find out what kind it is you may recognize it hear: http://www.barcodesinc.com/cats/barcode-scanners/cordless.htm good luck.
Oct 01, 2009 | Office Equipment & Supplies
ALSO HAVE PRO2043 SCANNER THAT WAS MY DAD'S--CAN'T FIND A MANUAL-
Here's a link to the Radio Shack info page for this scanner. The OPERATION section discusses programming.
http://support.radioshack.com/support_electronics/36545.htm
For a comprehensive database of active frequencies in your area, visit:
Jun 25, 2009 | Radio Shack Pro-2018 Scanner
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Hi - You can download the manual by clicking the link underlined in blue below:
bc60XLT
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 04, 2008 | Uniden BC60XLT Handheld Scanner
43 people viewed this question
k24674
jasbo
jasbo
