Question about Printronix P7005 Matrix Printer
Re: Printing Garbage
We have a Printronix 7005 printer connected by HP JetDirect printer server to our network. The printer was configured in iSeries(AS400) as Remote OUTQ ,
RMTPRTQ > 'lptprt1'
MFRTYPMDL > *HP5SI
It prints garbage like:
E
E
(%OU
(sop10...
Please helps..
Daniel Zhang
Sunrise Logistics Solution (America), Ltd.
1640 West 190th Street Torrance, CA 90501
Phone: (310) 755-3728 Fax: (310) 755-0334
dzhang@hitachitransport.com
  • Tim Babcock
    Tim Babcock May 11, 2010
    Can you disconnect the printer from the server and hook it up locally?
    It could be the print server and not the printer
  • 31 Answers
I believe you have this setting incorrect: the MFRTYPMDL should be *IBM6400EP. That is because you want the AS400 to send out plain old ASCII to our printer. It is an ASCII printer and not a HP. The codes are different.
Posted on May 29, 2009
Can the Printronix P7005 PSA3 print PDF files?
Sounds like your printer may need IPDS, I'll need to see a configuration page from your printer in order to determine whats on it. you can email me it at rcardenas@mrp.to
Apr 09, 2013 | Printronix LineJet® P7005 Printer
Printronix P5215. Upgraded this printer to use Eternet card. Whenever i send large print jobs thru my AIX queue the printer will fail at the end of the job and just stop printing. I can switch back to
I've seen a very similar problem with the L5000 series printer.
It turned to be that the problem was with HP jetdirect that the customer used instead of the printronix printnet.
Several jetdirect were used and all cause a similar problem.
When the printronix printnet was used everything worked fine
Jul 18, 2017 | Printronix Line Matrix P5215 Printer
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
We believe the problem with our LaserJet 5000 GN is the JetDirect 610N network connection on the back. It prints its own internal documents just fine, so we know it's not that. And the network itself seems...
New Part Number is J7934A it is newer version and costs about $75.00 . To test the jet direct, press menu and then information, print the configuration page, if more then 1 sheet comes out 1 will be for the jet direct if this prints there is nothing wrong with the Jet Direct. however if you are printing through the network and you are getting any type of special characters like $%^ it is most likely a driver issue, uninstall the printer and reinstall using PCL 6. You can go to HP's wesite for driver support. Hope this helps.
Jan 03, 2011 | HP JetDirect 610N Print Server
Problem scanning with a Xerox 4118x printer
you might have to configure the scanner manualy
May 24, 2010 | HP Jetdirect 175x Print Server
I'm pretty good at most computer stuff, but I'm stumped. I'm trying to connect an HPlaserjet5/5m to an HP 170X Print Server on a 16 port dlink switch. I cannot get the hp setup.exe to work off the...
I am not sure if you need the setup.exe file to configure the JetDirect 170x.If you take a look the manual for the JetDirect 170x (http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf) it mentions that this is a "Test" button on the back of the print server. If you press that button when the printer is connect, then it should print out a configuration page. The configuration page will have an IP address that you can browse to with Internet Explorer to configure the JetDirect.
Jun 05, 2009 | HP Jetdirect 170x Print Server
HP JetDirect 500x to HP DesignJet 450c printing issues
connect the jet direct card to plotter ,press the print test button locaed on jet direct card, it will print a configuration page & locate the hardware address from that page .Then try to iunstall it using hardware mac address
i m very sure it wil resolve the issue
mail me for further information
Regards
Neeraj
neeraj1412@gmail.com
Mar 24, 2009 | HP JetDirect 500X Print Server
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
Mar 06, 2017 | HP Jetdirect 170x Print Server
Printronix P7005 Matrix Printer Logo
430 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
