Question about Sony STR-DE325 Receiver
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
    Scholar:
  • 105 Answers
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Posted on Apr 05, 2011
    New Friend:
There is a jack for a sub-woofer on the back labeled "MIX AUDIO OUT" it requires an active (aka powered) sub-woofer
Posted on Apr 12, 2013
How to change the connector on subwoofer of coby 5.1 cs-p92 so that it can play with Sony str dh750 receiver
Before you cut any wires, make sure the sub woofer can handle the power from the Sony. Is the sub powered? What are speaker specs on the Sony . Is the output jack on the Sony meant for an unamplified sub? You have to know the answers to all this so you won't blow up the Sony and/or the sub woofer
Aug 21, 2016 | Sony Audio Players & Recorders
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
New sony receiver str-dh740 has 2 RCA plugs for sub woofer. How do I connect to psw350
only use one of the outputs from the rear of the str-dh740. and use a rca "y" adapter where you plug it into the subwoofer so that both of the inputs on the sub are getting a signal.
May 11, 2014 | Polk Audio PSW350 Subwoofer
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Cant get sony sub woofer model no. ss-wg60 working on my sony receiver model no. str-de445
First, go into the "setup" mode of the receiver and go to speaker select, then toggle to sub, highlight and make sure it's "on" Then toggle to speaker volume and check the sub level. Maximum setting is "0". Make sure you are connected to the subwoofer output on the receiver as well. If you still have a problem, post a comment and I can help you some more.Hope this helps
Jun 20, 2009 | Sony STR-DE445 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
SONY STR-DG510 Sub woofer does not work
You will need a powered sub because your receiver does not amplify in the sub output.
Jan 21, 2008 | JVC RX-554V Receiver
Patio speakers
connect them to the front left and right outputs.connecting them to the sub-woofer will give poor sound because it only pick's up bass sounds during playback
Oct 29, 2007 | Sony STR-DE575 Receiver
Sony STR-DE325 Receiver Logo
301 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
