Question about Garden
Hi I bought a Black and Decker powered handsaw I read the directions however I cant figure out how to install the blade could someone explain please thank you so much
    Master:
  • 403 Answers
What type of saw is it, need moor info
Posted on Apr 05, 2011
How do I change the blade on the black & decker powered handsaw PHS550 type 2
Go to http://www.manualowl.com/m/Black%20%26%20Decker/PHS550B/Manual/412144?page=2. Follow instructions.
Oct 05, 2014 | Saws
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
I have borrowed an old Black & Decker electric knife that has 2 blades with it. I don't know how to use it? both blades look the same, but you only have one it at one time don't you?
You use both blades together.. On one blade is a (should be) a small metal knob sticking out from the side. On the other is a matching hole. Hold the blades crossed at 90 deg. Lock the knob into the hole on the other and slide blades parrallel, side by side. Both blades should now slip into the slots in handle and lock into place. They will not be exactly level with each other. One will stick out further.. Plug in power, and push run button.. Blades slide back and forth against each other, just hold sharp side against the meat, and push button.. Cuts like butter..
To remove for cleaning, there should be a small button near where the blades lock in, on the bottom (?) push to release blades.. for washing.
Dec 09, 2010 | Black & Decker Black Decker Slimgrip...
We can't get the blade to go in
There should be a button on the right side of the saw to press in to open the clamp for the blade.
Blade changes require no tools. There will be a pin that engages the hole in the blades.
May 09, 2010 | Black & Decker PHS550B Powered Handsaw...
Black and decker electric mower
That is strange, I would maybe take it to where you bought it from and see if they will support you in it, or you can check out the tool repair forum over at eReplacementParts.com and ask a licensed mechanic to knows these mowers for some direct advice. Good luck to ya!
Mar 24, 2010 | Black & Decker 19" Electric Lawnhog...
Nstructions
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
Please copy and paste the entire link below into the address bar of your web browser. It will take you to a .pdf of the manual for your food processor.
http://useandcaremanuals.com/pdf/FP1510,FP1550S,FP1560872.pdf
I hope I've provided you useful assistance and that this informationallows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Jun 17, 2009 | Black & Decker FP1550T Textured Series ...
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Replacing Black and Decker 18" lawn mower blade
Black and decker has a web page and 800 number which I can't locate rigth now
Sep 20, 2008 | Black & Decker 19" Electric Lawnhog...
How do I replace the saw on the black and decker navigator handsaw
manuals are available at www.dewaltservicenet.com looks for
icon find it now.enter the model on the box & search
Jul 04, 2008 | Black & Decker 19" Electric Lawnhog...
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
