Question about Watches
My tanita 1579 digital scales often shows ERR error! still very new (2 month) takes almost a dozen try including taking battery off on and back on to actually make it work ! Thank you for your consideration and time to answer my problem. Michele
4 Suggested Answers
  • 183 Answers
SOURCE: new battery inserted.digital part of watch shows
First, take the back off the watch and make sure that the movement is inserted correctly. When buttons dont come back out it is usually the movement in the case wrong or the back is put back on wrong. If it is a pop off back then you want to be sure the dimples in the back are over the stem and crown and buttons so they move freely. Also, be sure that any springs that were in place are still in place.
Now i dont know what brand or model of watch this is but most digital analogs have a stem and crown to set the analog. Pull out the stem to the first position and set the time.
For specific instructions please leave the brand and model.
Thanks!
Posted on Sep 19, 2009
SOURCE: Set watch time - digital
I looked up the web site for Timex and called the Customer Service line. The technician there helped me set the time and other features over the phone.
Posted on Jul 23, 2008
SOURCE: i have a tcm 217362
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
Posted on Jul 27, 2011
The last two batteries only lasted 9 months. Only Citizen can replace them and it is pricey and takes a month to get it back. Any reason why the battery is going so quickly? The second hand was double...
Take the watch to your local jeweler. They may be able to use a same size and voltage battery in a better capacity using Lithium or Silver Oxide.
Jul 14, 2018 | Citizen Watches
Digital working, hands don't
digital and analogue watches have 2 different batteries,I believe you need to replace the battery of the analog part ..just reminder,so save money and time you can replace both at the same time to prevent to replace the digital one 2 months later.!
Hope this helps!
Take care and please Remember to rate/vote for us to continue for Helping out the Community :)
Thanks
Jul 04, 2011 | Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
7.
May 15, 2011 | Watches
Seiko 5m43 fails run after cell replacement
Hi, Look on page 11 of your manual for the proper procedure to restart watch after a battery change, or complete discharge of capacitor system. If you don't have the manual, Try this link:
http://www.seikowatches.com/support/ib/index.html
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 08, 2010 | Seiko Kinetic watch
The screen is fading
I think that the battery needs replacing.
cement
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 05, 2010 | Polar F6 Wrist Watch
My Seiko never seems to charge enough to pass the first "indicator" scale. After a few minutes of charging it by swinging it back and forth, then wearing it all day and night; the next morning I get the "2...
There seem to be three possibilities
(1) the battery is not taking charge
(2) the generator is not charging the battery
(3) you need to swing it for much longer (one maker said swing their watch several hundred times!.
I suggest your try the easiest first i.e. No. 3.
If this does not improve things, go to your nearest dealer and discuss your problem with him.
If you need a service center, you can find out where one is by going to their web site (seiko.com) and click on "support".
Feb 13, 2010 | Watches
Stuck on 02.10 hrs
You have to change battery. 3 years was a quite long service time for one battery. After replacement your watch will work as brand new. Rate me, plz.
Feb 03, 2010 | Tissot T Touch Navigator 3000 T96.1.488.42...
Digital deisel watch screen blackout
some time these watches takes 2 battery
and required ac & battery + connection
hope this help
From
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Diesel Watches
New battery inserted.digital part of watch shows correct time.clockfave shows different time.also the 2 buttons on the side when pressed in do not come out again
Thanks!
Sep 19, 2009 | Watches
My old field watch is showing an err (error) and the internal klight wont work
I changed the battery in my PRT 50 but Alt and Baro still not working the light and Compass however is??
Oct 27, 2007 | Watches
Watches Logo
723 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
