Question about Samsung 61" Slim-Depth DLP HDTV
What is the dlp lamp number for Samsung HL61A750A1FXZA
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
I am not so sure , because difference engine difference lamp.
Make sure that lamp same with spec in your TV set.
BP47-00023A , LAMP;UHP 120W/132W 1.0,E22,65*70,LL
BP47-00018A , LAMP;UHP 100W/120W 1.0,E22,65*70
BP47-00041A , LAMP;300W PHILIPS LAMP,200MM,56*56,132W,
Thanks.
Posted on Apr 05, 2011
Samsung DLP tv white color turned to yellow
go into menu reset picture settings to default
red , tint or gamma is off
Nov 15, 2016 | Samsung Televison & Video
What Bulb for HL61A750A1FXZA
Google the model number with lamp and take your pick
Nov 27, 2012 | Samsung HL61A750A 61" HDTV
I have a Samsung dlp, the front LAMP flashes and there is a humming noise from the left side. What is the issue with th DLP?
Color Wheel. Look up your Model on this website
Encompass Parts Distribution they will list Part/number and their Prices. I found my lamp on Ebay for $85.00 and Ballast board for $65.00.
Also here on FixYa was a Post with Sevice Manual showing you how to Replace Color Wheel.
May 03, 2010 | Samsung HL-R4264W 42" DLP HDTV
Samsung tv model# HL-S5679W all three lights on front panel blink, no pix or sound owner's manual says lamp may be defective this is a DLP-LED. No conventional single lamp
The "lamp" in this set, I think, is called the "DLP" in the parts listings. That part is number: 4719-001960 and can be purchased from tritronicsinc.com for $249.75 plus shipping. Use the guest account to access this info.
Hope this helps,
Dan
Feb 17, 2010 | Samsung DLP HL-P5663W 56" TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP TV
No best buy doesnt carry replacement lamps. You can go to this link that I am posting and email them with the model number of your set, as they have about any lamp that you would require. heres the link.
http://servicemanuals.vstore.ca/
May 03, 2008 | Televison & Video
Bightness Change
It sounds like your lamp is going bad. The lamp part number is listed as "lamp code" on a sticker located on the left side of the set. Use this number to grab a replacement off ebay.
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung 61" Slim-Depth DLP HDTV Logo
569 people viewed this question
Henry  Thomas
Henry Thomas
