Question about Toys
9.6 volt nicd , how many cells are in this battery? \
    Problem Solver:
  • 12 Answers
NiCd is 1.2 Volts per cell nominal, so 8 cells in series is 9.6 Volts
Posted on Apr 05, 2011
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
Feb 28, 2015 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Drill master, model 93440 battery needed
Your best bet might be to rebuild those NiCd batteries if they cannot be revived. It is possible to revive NiCds by using 2 good batteries or a high power DC source of about 40 Volts. The details for reviving NiCd batteries are all over YouTube. I suggest you watch a few before attempting to do this. Results are mixed. They may come back almost 100% or they may be done for. In that case you will need to rebuild with new cells. Harbor freight tools are throw away tools. They are cheaply made and have poor support.
Feb 17, 2013 | Chicago Electric Drills
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Where can I get battery power pack(shell with recharchable batteries inside) for metz 45 cl series,good second hand,off market brand,or even geniune brand,thank you
I have a lot of old 45-40 Series Metz 45 NiCd battery packs, that I will eventually rebuild with new NiCd batteries. I got them from Photographic Trader magazine and from ebay. I've heard that NiCd cells are going out of production, in favour of NiMH cells. I've found it's easier to put NiCd or NiMH cells in the alkaline battery holder, the flash recycle time is only slightly longer. I charge them separately out of the holder, or in the holder with a connector I made. NiMH cells need a suitable charger, with peak detection, as NiMH cells don't like being overcharged.
Nov 05, 2010 | Metz mecablitz 45 CL-4 TTL Flash
Changing rechargeable battries 45-40
Metz 45-40 consist of 6 nos of NiCd - AA size batteries connected in series. These battery packs can be rechanged by resoldering new set of AA size rechargable Nicd battries. Care should be taken not to short circuit the cells when disassembling and assembling the cells. Keep a note (sketch) of the connections of the cells, specially the longer connecting metal strip and the polarities of cells. re-solder the new set of AA size NiCd Batteries. If the old wires were corroded, use new wires' If the connecting terminals also corroded' clean it. If it is severely corroded, get it plated prior to fixing for better performance.. There is an charging indicating lamp which also control the charging current of the batteries. check its connections and solder it if required. I wish you got the answer for your problem.
H.D. Shirantha.
Sep 07, 2010 | Metz 45 CL-1 Flash
What charger should I get for my Evader EXB
I show your car uses 8 “AA” batteries, 6- or 7-cell NiCd or NiMH battery.
Radio Shack or The Shack will have a replacement and the store people should be able to guide you to the correct plug and polarity. NiCD and NiMH batteries are easy to work with, buy, replace and charge. If you use 8 AA batteries, that is 8 X 1.5 (volts) = 12 Volts DC. NiCD and NiMH style batteries should deliver about the same but dont expect to get performance from a NiCad battery as they dont offer enough power.
Apr 09, 2010 | DURATRAX Evader Exb 1/10 Electric Buggy...
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Defective Ni-Cad Battery
Try Re-Conditioning the battery first. Full procedure at: ysuusy.com/easybatteryfix.html
"Cordless Power Tool Batteries and other batteries that contain Nickel Cadmium (NiCd) Cells can be Re-Conditioned to perform as well as new or even better than new. Proper maintenance after the procedure will insure years of usable life.
The First and most common procedure for Re-Conditioning a NiCd cell is by using a Technique called "VOLTAGE SURGING". Over time the crystals within a NiCd cell begin to combine and get larger. This causes them to loose capacitance and also break through the inner seals of the cell.
Surging the NiCd cell using a higher voltage causes the crystals within the NiCd cell to shatter and become smaller. These smaller crystals have a greater surface area and therefore contain a greater capacitance for energy. "
Jan 17, 2009 | Batteries.com 8148 Nickel Cadmium 2-Way...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
