Question about Garden
Ariens Riding Lawnmower - zero turn Model #915013. PTO won't engage. Replaced PTO switch still did not fix. Any suggestions or where I can find a repair manual?
  • 376 Answers
SOURCE: Toro mower is blowing 30 amp fuse
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
Posted on May 24, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
  • 18 Answers
SOURCE: poulan pro hydro 18.5-42 riding lawnmower - back
Your hydro transmission is low/out of oil or it need to be rebuilt or a new one.
Posted on Jan 18, 2010
SOURCE: My riding lawnmower blades will not disengage or
my mtd 600 series riding mower will not disengage blades. blades are always on even with deck up
Posted on Sep 05, 2010
Ariens ZTR 1540 zero turn riding mower trembles real bad and chokes out when PTO is engaged
look at blades for bent or damage--check pulleys ,belts and mandrels ,bearings for binding or loose bolts
Aug 11, 2016 | Ariens Garden
Ihavert42.zero turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Ariens model 915111. Blades will not engage. Using a light voltage device. I placed the probe inside the socket which was connected to the pto clutch and it lit up. Can you tell me what part needs
If your receiving power at the PTO clutch and it is the correct voltage ie. 12vdc then you will need a new PTO clutch assembly.
Oct 28, 2014 | Garden
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Aug 03, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
When I pull the PTO lever up, it does not engage the blades.
you will need to check and see if the voltage is getting to the pto itself if it is then the pto needs replaced if not then the switch is bad
Apr 17, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
161 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
