Question about Amana NTW5100TQ Top Load Washer
Motor does not turn in wash or rinse mode. works fine in spin cycle. Humming from motor in wash/rinse mode. I removed pump and can spin motor by hand counter clockwise and agitor moves fine. turn motor clockwise and drum spins. (used pliers, hard to turn by hand) Possible bad diode in motor? I'm guessing motor turn oposite direction depending on cycle, wash or spin.
  • 1 more comment
  • daomax Apr 05, 2011
    It's obviously a two way motor. Of course its going to turn harder one way, it's trying to spin the whole washer drum vs just the agitor which moves very easily by the way. Works fine in spin.
    Hangs up in the agitate direction but I can turn the motor rotor easily just by push in the rotor fins with a screw driver. So I guess the question is what controls the motor direction?
    Its obviuosly a two motor. Its going to turn harder in the spin direction because it has to trun the drum vs the gear reduced agitator. Acts like the motor is trying to turn both directions in wash/rinse mode. What controls the motor direction?
    Not reallly, The problem is a short in the the timer module. (the control board as you call it, although this model is not electrronic). Oh by the wa,y thanks for attempting to crash my computer with your virus/trojan loaded links.
  • Amana Master
  • 12,061 Answers
Hi, well NO it's not the motor and there are no diodes inside the motor, thats not actually the way they in which they are made to rotate and reverse direction.
This is done by "Driving" the motor with a pulse width modulated signal, that makes the motor spin,as the electricity is switched from pole to pole the motor's stator is attracted to that pole and moves forwards or backwards depending on the direction of the waveform.
So whenever a motor isn't working, spinning, then most often if the motor works, as it actually appears your is OK, then the "Controller' is at fault. The controller in this case is the Main Controller Board. This must be replaced in it's entirety. If you wish to DIY, then please find below a service and repair manual, to use to try and track down exactly whats wrong...
http://www.appliance411.com/service/repairmanual.shtml
http://www.scribd.com/doc/8677902/Amana-Top-Load-Washer-Service-Manual
service and repair manual above..
But you see these days, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center,Anma in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option.
Posted on Apr 05, 2011
  • 1,998 Answers
First thing the motor if it were good would spin easily in both directions on some motors they are a 3 speed that all go one way on others it would be a two way where one way would be for the agitate compared to the oppisite way for the spin I would also suggest when you order this part you say you want the motor kit or the motor in the sears aspect just the motor they have it listed for 132 and the switch is another 70 dollars which to me personally is a total rip off for this part try www.marcone.com under contact us there is a 1800 number you may get a cheaper price from them and they ship anywhere if you have any further questions message me back and I await your reply Thanks
Rick
  • Rick Ead
    Rick Ead Apr 05, 2011
    it wouldnt turn harder as to with a pair or pliers though when you said this you described the same situation as a siezed motor thats why you are able to see the problem at hand being with the unit and as you already found out the timer controls the motor direction and who posted links with trojans?I await your reply Thanks Rick
  • Rick Ead
    the post from marcone wouldnt be corrupted its the largest appliance parts company in the world Idk what you are talking about with trojan activity?
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
I have a Frigidaire front-loading washing machine, model# FTF2140ES3 (serial# XC63816300). It works fine through the rinse cycle, but does not drain or spin. If I turn it to the rinse/spin only cycle, it...
Hi
Thanks for using FixYa. Please check the water pump. Either the water pump bearing is bad or there are some tiny pieces of debris stuck in the water pump. It is located below the door latch assembly. Remove the front panel and check the drain pump which is attached with hoses. Remove its clamps and clean the drain pump. You can also remove the drain pump by unbolting it from the washer base. If still the issue persists, then check the motor speed control board which is located inside the bottom of the washer. Please do accept the solution if the issue is resolved or
post a comment for further assistance.
Thanks
Rylee
Jun 08, 2010 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Not Spinning or Draining !
Hey there
well from what I can understand here you need to check first 2 things
1) Check that the hose that is connected to the machine is empty and that there's nothing blocking the water.
2) another possiblity is that your Pump isn't working.
saince i don't knwo the model I can't tell what kind of pump you have, if you have direct pump is should be abouve the motor, it' pretty easy to inspect it and look at it, it may be blocked from all kind of junk (coins.....) another option is that the pump blades are worn out so it's not pumping ( i don't think its your case since your washer is prettry new)
Hope this helps
Bono
Mar 24, 2008 | Washing Machines
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Amana NTW5100TQ Top Load Washer Logo
134 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
