Question about Panasonic Cell Phones
I purchases a kx-tg4393 ~3 handsets phone is it possible to add an (1) addition phone, if so where and how do i order?? Thanks Peter D Woodward 0417 161903
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Posted on May 30, 2008
mrfixit64857
  • 9 Answers
SOURCE: sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Posted on Jan 01, 2009
  • 514 Answers
SOURCE: Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
Posted on Jan 09, 2009
SOURCE: how do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Posted on Feb 23, 2009
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Is it possible to change the Panasonic KX-TG6541 hand set numbers ? speaker stopped working so I want to change handset #1 to Handset #4 & Handset #4 to Handset #1
yes de-register most of the phones from the base station and then
re gister them in the correct order to get the desired numbers. You have the instruction manual from my earlier post so just de register most of the phones being 2 to 4 and re resister them in the desired order .
Dec 20, 2014 | Panasonic Lands Phones
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Sync a new handset to kx-tg5632 phone
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
indicator flashes.
minute.
3 Handset:
sounds.
4 {OFF}
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Would like to add another phone to KX-TG2352 system (we have 3)
The KX-TBG2352 can only support a maximum of 3 phones. Sorry.
Nov 11, 2008 | Panasonic KX-TG2352 Cordless Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Cell Phones Logo
41 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
ray gallant
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
