SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
SOURCE: what setting do I need to weld aluminum for a 135 miller mig weld
start slowly turning up the wire feeder,and the amps till you get the sound of bacon crackeling and youll know your there. hope this helps jojogunne
SOURCE: Toolex 140 mig welder, wont feed wire.
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
SOURCE: have a lincon 255Xt mig welder. You push the
Have you checked the tension on the wire roll feeder? Inside the unit where the spool is, the wire feeds off of the spool, through the feed roller, this roller has a tensioner spring on it that keeps the wire flowing steady, and also check the spring tension the keeps the spool from turning freely, keep this loose as can be, and just enoughthat it doesn't unwind on it's own.
There are so many things that it can be, but this is a start.
Good Luck.
Paul
