Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Water in W510
Yesterday 8/4 phone got wet. Right away the screen showed all 7s - occassionally I can text or look at the phone book but only for a few minutes (15?) at a time. Anything I can do?
We used a hair dyer and it cleared the problem within minutes.
Posted on Aug 06, 2008
Samsung convoy
If the phone got wet and the screen went out. That means there's water damage and the phone is fried.
Keep phones AWAY from water at all times. Water resistant or not.
Jan 10, 2012 | Samsung Convoy Cell Phone
Just got this phone yesterday! dropped in water... pulled out and shock water out and dryied it with a hair moisture appears on screen. Dried battery...waited an hour and put on charger..the...
There may be some water logs present in the phone which obstructs the functioning of the phone.
Never switch on the wet mobile,When the power goes to the circuit board it may short circuit the full mobile motherboard.DONOT put your mobile in charge when it is wet it may be very dangerous.
You need to remove the water logs present in the mobile. So,please go to mobile service centre in your place and they will fix it.You cannot fix it yourself.
Aug 07, 2010 | Cell Phones
How do i customize ring tones? (i.e. use my own music, etc.)?
Please find steps to customize ringtones.
Note: in order to be able to use this method one has to have two Motorola phones: the W510 and an older one that isn't ringtone-locked (I tried a V190 and and RAZR V3 and both worked).
First create a backup directory on your drive and call it something like "Original Motorola W510 audio directory". The name doesn't really matter as long as you can find it later if you ever need those files again. Next install the ringtones you want to have on your W510 to the old uncrippled phone.
Then follow these steps:
Step 1 - Connect the W510 to your computer via USB or Bluetooth
Step 2 - Fire up P2K (latest version)
Step 3 - In the right pane navigate to P2k:/c/mobile/audio/ on the W510; in the left pane navigate to the backup directory you just created on your hard drive. It will be empty.
Step 4 - Select all the files in P2k:/c/mobile/audio/, right-click and select "copy", the files will be automatically pasted in your backup directory.
Step 5 - Delete all the files in P2k:/c/mobile/audio/. Once this is done the "audio" directory will have vanished so it's possible that P2K will crash, this is not a problem.
Step 6 - Create a new directory on your disk, name doesn't matter. Unplug the W510 from the computer and reboot it (the phone), then close P2K (if it hasn't crashed already) and plug the older Motorola phone into the computer, wait for the computer to recognize the new phone, then restart P2K. On the right pane navigate to the old phone's audio directory (same location as on the W510), on the left go to the new directory you have just created.
Step 7 - use the method described in Step 4 to copy all the files in the audio directory to your hard disk. *Do not erase any files in the old phone's audio directory*
Shut P2K down and unplug the old phone from the computer. Plug in the W510 and wait for the computer to recognize it. Once this is done fire up P2K once more.
Step 8 - Remember that the audio directory on the W510 is gone, so you can't navigate directly to it, you need to create it first. In the right pane go to /c/mobile/ and select "New Folder" from the menu at the bottom of the pane. Name the new folder "audio" and navigate to it.
Step 8 - In the left pane navigate to the new directory on your hard drive that contains the audio files from the old phone.
Step 9 - Copy all those audio files to the new audio folder you just created on the W510.
Step 10 - That's it, your W510 now contains every single ringtone that was on your old phone and all of them now have the "apply" option enabled so the W510 will now accept any of those sounds as a ringtone.
Unfortunately the W510 still won't accept sounds from any other source than the old phone but as long as you're able to get those those sounds (inclding custom sounds) to register as ringtones on the old phone you'll be able to transfer them to the W510 using the method described above. It's a little tedious but there ain't no such thing as a free lunch is there
Nov 21, 2009 | Motorola Mobility W510 Mobile Phone
My phone got wet
ur mobile keypad might got slight damage... since it got wet.... u can go to th authorised service centre for motorola an get ur keypad service.... so that ur prob get solved..... kindly rate me .... thank you....
Jul 01, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Doesn't ring loud enough.
Simple, when the phone is ringing, knock up the volume button. The ringer will get louder.
Feb 10, 2009 | Panasonic VB-43223 Corded Phone
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 08, 2009 | Sony Z310a Cellular Phone
My texting is messed up
the phone is just slow but if you want it replace just take it in if it is still under warranty
Nov 30, 2008 | Sanyo S1 Cellular Phone
Transfer phone numbers
sorry it would be best to have the phone repair or the mainboard place into another w510 and then transfer the contacts to the simcard.
Sep 16, 2008 | Motorola Mobility W510 Mobile Phone
Motorola Razr text message.
check the time zone your phone is set in?
Oct 26, 2007 | Motorola Mobility RAZR V3
Stuck buttons?
Yea dude, my piece just started having that problem. It seems like the buttons are stuck, or like some presses them and such. I can't check my text's or look at my menu or nothing when its doing it cause my 9, 6, and 8 button always pop up or act like there being held down. Well,I don't know how you got this problem but mine showed up after I texted someone with a wet hand. So I'm sure theres water under my keypad or this little frameware device or whatever its called.(it runs your keypad...i guess) Frameware can only activate one key at a time. So I'm thinking I need a new little computer thing called frameware, or to take apart the keypad and make sure theres no water in there, even though after to days, the water should be dried up. So if it got wet, bring it to your dealer an see if they can replace the little computer deal, unless it's more than the phone itself. And if you just so happen to live in the desert and that phone had absolutely no way of getting wet, i guess them things just happen to go out for some reason. I dunno. I HATE THESE RAZRZ!!! haha. Good luck Morgan
Sep 17, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
