Question about IBM ThinkPad T42 Notebook
My IBM thinkpad T-42... when i turn it on it beeps and says "fan error" then shuts back off. It was working fine then i turned it off and when i turned it back on this happened. . whats wrong?
    Master:
  • 346 Answers
Hi Sam - The bad news is that your notebook fan has probably died. The good news is that if you hit the ESC key it will continue to boot and not shut off. It will run normally if you use it so the CPU gets a little air and ventilation.
For now you can place a book under the the machine at the rear (at the end of the book, so the book is only underneath the last 1-2 inches of the rear of the laptop and not covering the vent where you want air to flow). It would probably be alright that way indefinitely unless it's being used in very warm room.
Ideally the best solution would be to get the fan replaced by a repair shop which would cost about a $100+. The cheapest way to fix it permanently without repair is to buy one of the many notebook cooling pads available (they hold the machine and have 1-3 fans to keep the notebook cool) they cost $15-50 with the most expensive not always the best (Google for reviews).
there is a possibility that the fan is just very dirty and kind of stuck - to find out use a household vacuum with the hose part (with the laptop off and the power cord and battery removed) and vacuum (not for to long) at the left side rear, back rear and underside (again left rear) vent. If it boots without the fan error you're golden -- If not see previous paragraph.
Good Luck and Thanks for using Fix Ya
Mikeywaf
Posted on Apr 05, 2011
Thinkpad X41 starting two short beeps, fan error and shuts of
The IBM POST code states that after the 2 beeps the screen displays the error.
In the case you have a faulty fan and it needs to be replaced.
Sep 19, 2012 | IBM ThinkPad X41 Notebook
I have an old IBM Thinkpad A31. When I power on, I get the IBM Thinkpad logo on screen, the fan turns on, but after about 15 seconds I get 2 beeps and it shuts down. I suspect that the hard drive is...
2 short beeps actually refer to RAM. If you are comfortable re-seating the RAM to it's place, then do it. If you still have the same issue, then it's the motherboard.
A click on YES will be greatly appreciated. Thank you for choosing FixYa!
Jun 24, 2011 | IBM ThinkPad T42 Notebook
I get 3 beeps on start up and a continuous dark blank screen
On the IBM Thinkpad 3 long beeps should mean "critical thermal" After it cools down will it start again?
http://www-307.ibm.com/pc/support/site.wss/MIGR-39706.html
Is the fan still working blowing air out the back or side?
Feb 02, 2011 | IBM ThinkPad T40 2373 Notebook
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
Alarm won't turn off (unless I mute the sound.)
The beeping is telling that the laptop is not fine and wants you to do something about it.
One of your memory cards may have come out of its slot or the CPU has come loose or something worse....get a copy of your manual and see if you have a beep code error list, if not contact your laptop maker.
Thanks
Sep 05, 2009 | IBM Lenovo ThinkPad X40 Notebook
Fan error on ibm thinkpad
take it to the technician remove the fan clean the dust then put it again if its not working then change the fan
Sep 04, 2009 | IBM ThinkPad G41 Notebook
Thinkpad T21 Boot Problems Problems
This is caused by a system board failure. Take the laptop apart again and check all of your connections. Also make sure the ram and processor are seated correctly. You can also try hooking up an external monitor to see if any errors display. This may be an indication that the video cable connected to the system board is not fully connected.
From IBM website:
Two short beeps - System board failure
Dec 20, 2008 | IBM ThinkPad T21 Notebook
Laptop Fan?
Before getting the fan replaced you may want to try to blow the fan with an air compressed duster. Worked for me. You do not need to take the laptop apart completely. There are 4 screws that holds the keyboard in place, unscrew the 4 and you should be able to pop the keyboard out. Once the keyboard is off you should be able to clean the fan.
May 13, 2008 | IBM ThinkPad T40 2373 Notebook
A21m keeps shutting down
Have you checked the ventilation area of the processor if it is blocked by dirt? It causes heat to processor, when it reaches a certain hot temperature, it automatically turns off to avoid further damage. Have it opened and be cleaned by a computer tech
Jan 24, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T42 Notebook Logo
155 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
