I recently purchase a new laptop computer, but it does not have any where to plug a telephone line in. It has an ethernet connection, but not a telephone connection. Is there some kind of adapter that I need to get that will make my new laptop telephone compatable. I still have dial up modem at my house.
    Master:
  • 451 Answers
If you do not have a telephone port on your laptop
you will need to purchase a modem.
you can find a USB modem from newegg.com
http://www.newegg.com/Product/Product.aspx?Item=N82E16825104006&cm_re=usb_modem_56k-_-25-104-006-_-Product
I have used and purchased this for a client and it works well.
Posted on Apr 05, 2011
Connecting to my network
Its not a modem its a router. A Modem plugs in to a Telephone line. A Router plugs in to a Broad Band Line. A Modem connects to a RJ11 Cable. A Router Connects to a Coaxial Cabal, the router connects to a computer via wireless or ethernet after that. A Modem connects to a computer using RJ11 or RJ45 Cat4 Ethernet. Very different.
Aug 26, 2012 | Dell Computers & Internet
How do i connect phone to laptop connection
So do you have internet service at the house? If so you can plug the ethernet cable from the modem directly into the computer's ethernet port.
If you're talking about directly connecting to your cell phone, then the phone has to have the built in router in it. If it does, you can connect your computer to it wirelessly.
If you're talking about a regular old house phone (land line) then you would be very slow if you could get it connected. I don't think the newer models of computers even have a modem port to connect a telephone line into it. But basically you would still need a internet service provider to connect it.
Bear in mind that there is a difference between the phone cord and the ethernet cord. The phone cord is smaller in size and the end that plugs in is smaller.
Apr 03, 2012 | Computers & Internet
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
We bought the AT&T Motorola DSL Modem today, and we're trying to connect to wireless on a laptop and the connection isn't showing up. How do we fix this ?
  1. Ensure that your AT&T DSL self-installation kit is complete. At minimum, it should contain a DSL modem, an AC adapter, an Ethernet cable, a telephone cable, several telephone filters and an installation CD.
  2. Install the telephone filters on each telephone jack that you have a phone plugged into. Install a dual phone adapter on the jack closest to your computer if you have an answering or fax machine, telephone or analog modem in the same room. Then plug your telephone equipment into the filters. Connect the telephone cable that was provided with your installation kit into an unfiltered telephone jack.
  3. Insert the installation CD into your CD-ROM drive. If the installation program does not start automatically, click Start > Run > and browse to the CD-ROM drive directory to find the installation file.
  4. Connect the telephone cable that is attached to the unfiltered wall jack to the back of the DSL modem. Connect the Ethernet cable to the back of the modem and to the Ethernet network interface card port on the back of your computer. Connect the AC adapter to the back of the modem and plug it into an electrical outlet. Power the modem on.
  5. Check the modem lights. There should be at least two lights lit. These will have labels such as "Power" and "Ethernet." However, these labels may differ depending on the model of modem you received in your installation kit.
  6. Complete the software installation. Enter your chosen username and password when prompted. Check your modem to see if the light labeled "DSL" or "Internet" is lit. Open a web browser window to see if your DSL service has been successfully installed.
Oct 25, 2010 | AT&T High Speed DSL Modem
Wiring schematic for this router
Jehayman,
I am not if you are referring to the Ethernet connection when you said connections to the telephone line. Your WRT54G does not have a telephone port, it has an Ethernet port. If you would like to know how to connect this router to your network here is how you can do it.
If you look on the back of your router, there will be 5 Ethernet ports there (looks like a phone port but it's bigger). They are labeled 1,2,3,4, and WAN or Internet.
The ports labeled 1-4 are for your computer/s that will connect to the router through wired connection using an Ethernet cable. The port all by itself labeled WAN or Internet is where the modem should go to. If you dont have a modem from your ISP and just have a line that is plugged in straight to the computer, that line can be plugged in to that port.
Feb 07, 2010 | Linksys Wireless-G WRT54G Router
Is my lexmark 5470 compatable to my va10 all in one computer?
I am not sure what OS your new laptop is running, but I will assume it is Windows Vista if you purchased it in 2008. considering your printer is from 2005, you are not going to have Vista support on the software CD that came with the printer. The first thing you need to do is make sure you download the Vista level software for the device from the following location:
http://downloads.lexmark.com:80/perl/downloads/downloads.cgi?os_used=Windows%20Vista&mode=OS&ccs=229:1:0:549:0:0
Once you have this downloaded, run the Lexmark Uninstaller and install everything you have already tried to install and then reboot. Once you have rebooted the laptop, then install the new downloaded software and follow any instructions.
As far as another telephone connection, you should run your phone line into the device and most of these all-in-one devices have a line out to run another telephone line to the phone or modem.
Mar 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a belkin router without a integral modem, if i connect the telephone line straight into the computer then connect the ethernet cable into the input plug on the router how do i connect the computer...
Hi
First you have to connect the telephone line to the integral modem and then using straight through cable to connect the computer to the modem.
Jyothish
Jul 18, 2008 | Belkin Computers & Internet
My ethernet light is blinking
Make sure you have internet. The ethernet light is blinking because what ever u have plugged into it is talking to the modem. The modem will then take that request and ask for it on the DSL/internet line. Make sure the DSL light is steady on and the internet light is on or flashing with activity.
Oct 10, 2007 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
David Payne
David Payne
