Question about Garden
How to remove & replace bosch hedge trimmer blades model ahs 4-16
5 Suggested Answers
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 634 Answers
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Posted on Jul 09, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
  • 252 Answers
SOURCE: Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Posted on Sep 12, 2010
What is the best way to sharpen bosch AHS 45 16 HEDGE TRIMMER
Please understand, if you do, you may well start a business!
You will have to take it all apart, and then take either a file or a grind stone and resurface the blades.
I know you can learn this skill, if you do not know how, but this time it will take you to do it right will be hours, and if you charge a reasonable rate to do this for others, you may find it cheaper to buy a new one!
You may be able to find a web-site by looking on-line that will tell you exactly you to do this.
God bless your efforts.
Jul 11, 2016 | Bosch AHS 45-16 Electric Hedge Trimmer
My Bosch AHS 48-16 Electric Hedge Cutter hit a bit of wire, now there's s clickingn noise when trying to start it. Any help appreciated
It could have possibly damaged the cutting edge of the blades and put a burr on them, meaning that as the blades reciprocate, the 'burr' is catching on the other blade.. Check the blades for damage and use a flat file to smooth off any burrs that could be catching. (Make sure it's unplugged before doing any work on the machine)
May 10, 2016 | Electric Garden
I have a Bosch hedge trimmer AHS 52 LI and yesterday when I tried to fit the battery to the trimmer it would not fit
Make sure that you are using the right battery, positioning it right to match how it goes the receptacle. Last thing is do not be afraid to give it a good push in there. New ones in particular have a firm seating which can take a little bit to get it in.
Feb 20, 2015 | Bosch AHS 52 Li Cordless Hedge Trimmer
Bosch AHS52-16 hedge trimmer inop, changed fuse and mains lead. Are there any internal fuses or diodes likely to be faulty?
No internal fuses or diodes, but it probably has a set of brushes you can check and replace if necessary. Look for the brushes on both sides of the motor (you may have to open the case to do this). If they're there at all, one will be on each side of the motor at the "free end" (away from any mechanism).
Jul 31, 2014 | Bosch Protective Blade Cover for AHS 52-16
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
Oct 07, 2013 | Bosch AHS 45-16 Electric Hedge Trimmer
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Jul 21, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Cut Cable on Bosch Hedge Trimmer.
Been there. Done that. Now it is up to the "expert" to go back over the rewire job and find what's wrong and fix it. Oh yeah, I once used my hedge trimmer to shorten a brand new extension cord!
Jun 13, 2017 | Garden
cheers pauly46
Sep 19, 2009 | Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
