Question about Gateway GT5026E PC Desktop
GT5026E-turned on where it continuously runs, no indicator light, black monitor and won't turn off. Please what should I do?
  • 30 Answers
HELLO,
IF YOU HAVE PROBLEM THEN YOU NEED TO REATTACH ALL CABLES WIRES ,HARD DISK,CMOS BATTERY OF YOUR CPU CORRECTLY,,,,,,
Posted on Apr 05, 2011
Monitor won't turn on I have connected everything properly and still no signal
I didn't see whether the power strip where you have all devices plugged in was turned on. Plus, you only showed one side of the monitor. There should be an indicator light on the monitor which indicates that electricity is running through the unit. Lastly, did you read the owner's manual before putting this unit together? Check all options and let me know what happens.
Mar 06, 2013 | Computers & Internet
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Yamaha tdr indicators dont flash
Hi, Lucyemma2009 before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced you OEM lights with LED lights you are going to need a load equalizer. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Indicator doesnt flash it just stays on
http://www.apriliaforum.com/forums/showthread.php?179848-LED-Indicators-Won-t-Flash
http://www.yamaha-motor.com/assets/service/manuals/2007/LIT-11626-20-01_ttr125all_1961.pdf
OEM parts for Yamaha
YAMAHA TDR125 Owner Manual
May 06, 2011 | 2000 Yamaha TDR 125
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor on emachines computer is black and the on/off light flickers screen will not come on
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Jan 22, 2009 | E-Machines eMachines Monitor E15T4
1999 f150 airbag light stays on after blinking upon start up!
Passenger Air Bag Deactivation (PAD) Switch
The passenger air bag deactivation (PAD) switch:
  • is located on the instrument panel to the right of the climate controls.
  • contains a light emitting diode (LED) that indicates when the PAD switch is activated (passenger air bag disabled).
  • allows the passenger air bag deployment circuit to be disabled using the ignition key.
  • should be used whenever a child safety seat is being used in the front passenger seating position.
Prove Out the System
Prove out the system means to turn the ignition switch from the OFF to the RUN position and visually monitor the air bag indicator with the air bag modules installed. The air bag indicator will light continuously for approximately six seconds and then turn off. If an air bag supplemental restraint system (SRS) fault is present, the air bag indicator will either:
  • fail to light.
  • remain lit continuously.
  • flash.
The flashing might not occur until approximately 30 seconds after the ignition switch has been turned from the OFF to the RUN position. This is the time required for the restraints control module (RCM) to complete the testing of the SRS. If the air bag indicator is inoperative and an SRS fault exists, a chime will sound in a pattern of five sets of five tone bursts. If this occurs, the air bag indicator will need to be repaired before diagnosis can continue.
Active Commands
This command allows the technician to verify operation of the air bag indicator, passenger air bag deactivation (PAD) lamp and chime. When the air bag output command is executed, the indicator, the PAD lamp, chime and the chime are activated simultaneously for approximately four seconds. All devices are deactivated automatically.
Jan 15, 2009 | 1999 Ford F150 Regular Cab
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Gateway GT5026E PC Desktop Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
