Question about Dryers
It started to thump loudly and quickly. I turned it off as soon as it sounded wierd, but now it squeals as soon as I turn it on. I didn't finish drying the load that was in it at the time. Can you give me an idea what parts need to be replaced, and send me a wiring diagram or blueprint of the dryer? thanks in advance.
    Problem Solver:
  • 18 Answers
The guide or idler pulley needs to be replaced
Posted on Apr 05, 2011
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
Ac pump squealing
Try spraying the pulley with silicon spray, may help if lubed
Jun 17, 2014 | 2007 Jeep Commander Rocky Mountain
When i turn the key to start it up, it makes a loud squeal like sound, what is that?
starter may be going bad sounds kinda like a loud metal on metal grinding noise.
Apr 01, 2013 | 1990 Mercury Grand Marquis
When i first start to drive, there is a metal squealing noise followed by a loud thump. its coming from the front drivers side area. it stops as soon as i turn off the heater. the a/c runs fine and clutch...
Like all noise problems posted here I always suggest you have a local shop listen to the noise. The reason is this, can't hear the noise over this keyboard.
Sep 18, 2012 | 2003 Lincoln Navigator
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
Fan blade does not immediately spin when turned on; loud
The motor bearings need machine (like sewing machine oil).
Try a quick spray of WD40 or Liquid Wrench, but use machine oil, soon.
Look for an "oil hole" on top of the motor; there may be two of them.
Oct 05, 2009 | Lasko 2506 16", 3 Speed, Oscillating Fan
When I go to turn the wheel in my 2000 ford ranger I hear loud squealing noises. I checked the power steering fluid and its full. What can it be?The squealing starts as soon as I turn the wheel to the left...
The power steering pump is normally connected or driven by the engine with a V-belt. A loose belt can cause squealing as soon as the power steering come under load (e.g. steering left or right while stopped).
Check the tension on the V-belt directly connected to the power steering pump. This may need replacement.
Hoep this helps.
Jul 01, 2009 | Ford Ranger Cars & Trucks
Thumping noise while running
sounds like the bearings are bad or something is catch in the fan
Apr 03, 2009 | GE Zoneline AZ55H09D Air Conditioner
Squealing noise
sounds like a loose belt!!
Dec 13, 2008 | 2003 Nissan Pathfinder
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Dryers Logo
29 people viewed this question
Top Dryers Experts
