Question about Panasonic KV-S1025C
Im trying to scan tachos but get no target device. also have looked at internet and not connected any idea thanks
2 Suggested Answers
  • 16 Answers
SOURCE: can not Scan to Panasonic KV-S3065C High Speed Scanner
Since you are using USB, you will also need the STI device driver: http://panasonic.net/pcc/support/scanner/download.html#DEV_DRIVER
Posted on Sep 08, 2009
Hi i have a technika lcd 39 c-273 tv and when switched on just says DO NOT POWER OFF SCAN and just keeps continuously scanning, any ideas? thanks
It may be looking for a connection to the Internet to do an update download, or maybe a bug fix. Do you nave internet? At least check the manual for updating and what the requirements are. Maybe a bluetooth connection to the tv is being searched for.
Dec 11, 2014 | Televison & Video
Tip
How do I detect a Bluetooth Worm
<p>Bluetooth drivers can safely talk while driving through the network of your mobile phone with GPS devices or other machines, but there is a problem: hackers, worms and viruses were discovered Bluetooth navigation. Now the same security as war ravaged conventional Internet connections is through Bluetooth. A good Bluetooth security means more creative and think ahead of hackers. <br /> <p><br /> <p>1. Make the scan speed. Many scanners Bluetooth device on the market that allows users to find and protect vulnerable Bluetooth connections. Tools like BT Scanner, Audit and sweeping blue BT are among the many options. Find what suits you best for your own research. <br /> <p><br /> <p>2. Learn more about how Bluetooth devices worm priority target. The researchers say the virus finds devices in 'visible to all mode ", and selects the first available. Know the difference between the visible and invisible Bluetooth connections, and how to change them. <br /> <p><br /> <p>3. Select an area and time for a test. Set scanning transmission and environment monitoring. The revised list of devices in range and control their visibility settings: whether yours is vulnerable. Identify problems that would invite hackers and worms, and come up with solutions. <br /> <p><br /> <p>4. Look for data corruption on the device. A more low-tech solution to a worm or hack Bluetooth identifiable data to realize when they are damaged in a single device. It is a sign that something is probably wrong with the software. Especially with cell phones, corrupted data indicates that the device has been compromised. <br />
on Jun 26, 2011 | Computers & Internet
How do I pair with Samsung galaxy note 10.1 2014?
1. From a Home screen, touch Apps
Settings.
2. On the Bluetooth tab, touch the OFF / ON icon
to turn Bluetooth on.
3. Enable the target device's discoverable or visible
mode.
4. Touch the Bluetooth tab and then touch Scan. Touch
Stop at any time to stop scanning.
5. From the list of found devices, touch the target device,
then follow the prompts to complete the pairing:
• If the target device requires a PIN, enter a PIN for the target
device and touch OK. When prompted, enter the PIN on the
target device.
• If the device allows automatic or smart pairing, your device
attempts to pair with the device automatically. Follow the
prompts on your device and the target device to complete the
pairing.
Oct 19, 2014 | Microsoft Wedge Mobile Keyboard
Engine cranks no start key on engine off rpm reeds 575
i want to buy comma's so bad.
Engine cranks, but it don't start,
with key on,
engine off rpm reeds 575. (im cluesless here)
reads RPM 575 , not running and how pray tell did you
resolve the 5 at the end? what device showed that?
digital tacho or a scan tool? or dash tach? please tell this.
that is a good input , if true. the tacho on many cars is from
the spark primary signal, and if dead the car will not start.
is this a N.American car/ (unstated?)
the first checks (we go from easy to harder, and more tools)
1:got spark?
2: got fueling if spark is good, the ECU cuts fuel if it even suspects bad spark is true.
never look for bad fueling if the ECU reports bad spark.
that takes a scan tool to see what the ECU thinks, and sees.
got a scan tool they only cost $7, here.
If engine compression is at spec. W.O.T.
and spark is good.
then test fuel works all above is good,(mostly), if test fuel works
and it don't start up and stay running, with a fast right foot.
then the fueling system parts are bad.
this works for carb cars or EFI , this part is no different.
old school to new.
see scotty do it.
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Sep 26, 2013 | 2004 Suzuki Forenza
Im trying to install a tacho into my 1993 holden rodeo and i dont know where to put the revs wire as the isuzu engine 2.6 doesnt have a coil where do i connect the wire Cheers Dano
Hi Dano,
For installing the tacho on a vr there should be a single wire not pluged into anything, on your wire loom under the bonet on the LHS, this is the wire you need..
Please let us know if that was helpful enough.
Thanks
Shiv.
Aug 27, 2009 | 1993 Isuzu Rodeo
Windows vista laptop lost connection to the internet
Start off simple. Try a different port on the router. If that doesn't work, try a new cable. If that doesn't work, go to the Device Manager in Windows. (Right-click My Computer, select Manage, go to Device Manager). Does the card look okay? Has it been disabled or need a driver update? If we're still looking at issues then I would take a look at your router security. How many DHCP licences do you allowed to be assigned? Also do you have security in place (WEP/WPA, Mac Filtering, SSID Broadcast)? If you are light on security and only have a few assignable DHCP licences, you may have neighbors leeching your internet access.
To clarify: DHCP assigns a network IP address to each device on its network. Most Linkys routers have a default of 10, you may have reduced this yourself. If you have, you've limited the # of devices allowed on the network. So if you have 3 DHCP licenses available, and a couple neighbors are leeching, your Dell may not get assigned an ip.
If you still need further help, let me know.
Jun 24, 2009 | Linksys Ultra RangePlus Wireless Routr...
DI-514
PLEASE RATE ;] you can find out whos accessing your router by logging into it. Usually 192.168.1.1 once your in there is usually an option for attached devices or connected devices it should show you what computers or devices are connected to that router
Feb 06, 2009 | D-Link DI 514 Wireless Router (DI-514)
No sounds after format & reinstall vista to the IBM pc which has an inbuilt sound card NO SOUND PLUS INTERNET CONNECTS SLOW AND THEN WORKS FOR A FEW MINUTES AND KICKS YOU OUT. MESSAGE SAYS IT MAY BE A...
Update your motherboard drivers.
If you have the manual for your motherboard, itll tell you your devices.
Once you no the name of your network device and onboard audio device, you can just look
up the drivers on the internet.
Oct 26, 2008 | Computers & Internet
Problem scanning pictures
Check your documents folder under My Scans. I found that my scans were going in there. I had to open them to put them where I wanted them.
I also have the problem of the missing line up upload to my computer. If I restart the computer with the 6280 on the line reappears and I can scan what I want. I have asked HP what the problem is with no real solution. They seemed to think that since it works after restarting the computer that the problem was solved. The option shouldn't disappear from the screen at any time, but I guess I'm stuck with restarting the computer every time the problem comes up. Hope this helps.
Jun 30, 2008 | HP Photosmart C6280 Printer
Panasonic KV-S1025C Logo
125 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
