Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Hi: My Range model is KDRP407 dual fuel. Worked fine for 5 years until recently. Problems started while baking. We were unable to stop the baking process and simultaneously noticed the door mechanism was in lock mode. Also showed error code F02. Also had to remove power in order to unlock and reset oven. Could you recommend where I should start diagnosing the problem. Thanks Stan
5 Suggested Answers
SOURCE: oven is slow to start
Dear Friend,
I had the same problem and the first step you should take is to replace the bake ignitor, you most likely to have a weak ignitor. If this doesn´t solve your problem, than your gas valve is failing. Despite the broiler is ok, the gas valve has independent channels for bake and broiler, so it´s possible for one to fail and the other is good. But i believe that changing nthe ignitor will solve it.
Zanes
Posted on Oct 17, 2007
SOURCE: Broiler element comes on on Kitchen Aid KDRP407 on all settings
Have you resolved your oven problem ? If so, what was it ?
I have the same exact thing going on....
Brad
Posted on Feb 12, 2010
SOURCE: Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Posted on Jul 15, 2010
  • 906 Answers
SOURCE: No fire in oven on bake or broil? Stove works OK.
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Blue lights flashing can not get to reset
Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 26, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
After a power outage. All the lights on the range are blinking/flashing, how do I turn them off? Everything still works. Just can't turn off lights.
Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 18, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
I have a 5 year old Kitchen Aid duel fuel slide-in range. I have used clean twice since I got it. I tried to start clean today and it all went fine until I noticed after about 30 minutes that it was not...
Hi Cynthia
F5 error code normally means control board or clock failure. It means you will have to have a new control board and clock fitted.
Dec 18, 2010 | Ovens
Brad
Feb 03, 2010 | KitchenAid KDRP407H Dual Fuel (Electric...
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Oct 15, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
My frigidaire gas range oven won't work
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
May 21, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
62 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
