Question about Whirlpool LER4634J Electric Dryer
My dryer it got hot but it doesn dry i cleaned the duct
  • jerry earick Apr 05, 2011
    Does it blow a good stream of hot air out the vent?
  • Whirlpool Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Aug 15, 2011
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
Jun 05, 2016 | Electrolux EIED55H Dryer
Electric dryer taking longer to dry clothes
Must be past the filter-problems in the duct work and hoses. get one of the refrigerator cleaning brushes from the hardware store and a duct cleaning kit, or a rope and rag. clean out the dryer ducting, & hoses as good as you can and check the outside exhaust port. Sometimes these have trap doors that become stuck from old age, even though ductwork is relatively clean. problems can also exist after the filter but before the dryers exhaust port in the back try to clean that out as well.
Nov 09, 2013 | Dryers
Dryer gets hot but doesn't dry clothes
heatman101
Aug 19, 2011 | Kenmore Dryers
My stackable washer/dryer is taking at least 3 cycles on high heat before it will dry one load. It's heating up but it doesn't get hot enough. I've checked the venting and it is clear and...
heatman101
Jun 19, 2011 | Electrolux Dryers
Clothes are not drying especially jeans and towels. duct is clear and at end of cycle dryer is hot.
heatman101
Jun 14, 2011 | Kenmore Elite HE4 Electric Dryer
Not drying clothes like it use to. Have to run two or three times to get clothes dry.
you need to clean out the dryer.unplug the dryer.remove the vent line and blow it out with a leaf blower if it's a long run.make sure the outside vent is clear.next clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is.do this once a year and your clothes will dry on time,no fires and you'll change less parts if the dryer isn't running hot from blocked ducts.let me know how you make out
Apr 03, 2010 | Kenmore 62802 Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Dryer too hot...no cool down
no the thermal fuse has nothing to do with that,although it will open again if too hot and that may be why it opened in the first place.most high heat ,long dry times are the house ducting.try this experiment.remove your dryer from the house ducting and dry a load[it wont hurt a thing]if not as hot,then get that ducting cleaned.if still hot then make sure the inner dryer air ways are clean.your blower is spinning fine[not broken on the shaft]and also check with ohm meter,or visually that your heating element is not shorted to ground[then it by passes the cycling thermostat.if all those things good and still getting high heat i may replace the cycling thermo.but as a repairman i did not have to do that very often.most of the time it was the other possibles. i hope this helps abit God bless ,tom
Feb 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
