Question about Punch Professional Home Design Platinum Suite (26635)
Ceiling design Plank and beam with pitch
I'm going crazy. I almost have my kitchen design done but can't figure out how to draw an exposed ceiling beam that slopes with the roof pitch. Likewise with crown molding that slopes with roof pitch at top of the wall at ceiling. I cannot find any info. in the book manual or the help index on my Punch home design platinum version. HELP
Depending on your version you should be able to go to OBJECTS and add faux wood beams to the plans, which should slope automatically once added. This is how we spec faux beams on our projects. http://www.owtraditions.com
Posted on May 14, 2012
  • 73 Answers
I am not sure what Punch Plat you are using, however these are some notes and solutions that may help
1 - Crown moldings in Punch don't slope
2 - Ceiling beams --> check your Power Tools--> If your version has the Celing designer, you can use this tool to create the beams--> or use solution # 3
3 - Ceiling beams --> you can cevelop them in the 3D Workshop Power Tool --> set the pitch--> texture as necessary
4 - You will find ready to use beams in --> Obejcts--> Faux Wood beams
Posted on Oct 30, 2008
I have a Minerva 44" Fan. I have Vaulted Ceilings with a 12-12 pitch. The down rod is 3/4 in. What slope ceiling adapter is recommended ?
Mike, a 12/12 pitch is 45 degrees. You may have to use a little math to figure out how far down to hang the 44" fan to keep from hitting the angle of the ceiling. Geometry specifically. Remember the A sq + B sq = C sq for figuring the hypoteneuse of a right triangle?? If the ceiling fan is 44", the base (A) of the right triangle is 22" with NO CLEARANCE to the angled ceiling. A 45 degree angle dictates the base and the height are equal, so height (B) of the triangle is also 22" with NO CLEARANCE. If you want a few inches of clearance, extend the height by 4" and there should be enough clearance to allow the fan operation.
I would suggest playing with the figures before you buy the extension rods though. The simple answer to you question remains however...45 degrees.
Mar 08, 2015 | Dryers
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
I want to install a ceiling fan. My ceiling is 80 year old lathe and plaster design. Will the vibration from fan movement cause my ceiling to crack?
mcdevito75 here, Hopefully your ceiling fan will go where there has been an already light fixture, if so, that light fixture shoud be mounted to the ceiling beam, and your new fan will be mounted the same way. If by chance your new ceiling fan is being mounted where nothing was ever mounted you"ll have to make sure the ceiling fan will mount to a beam, they are every 16 inches apart. This way you:"ll know that vibration from the fan won"t hurt anything.
Jul 21, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Supporting a load bearing wall
The floor/roof loads above will be a bigger unknown than the ceiling itself. The wall MAY be replacable with properly sized beam/column combinations but you will need to have a design professional look for adauate footing size, calculate floor loads (and roof loads if any), and size the beam/column system to support ALL of the loads now carried by the wall. If you have access to the origional floor and roof framing plans they will be a great help, otherwise someone will need to do some investigating to make thoes design judgements.
In 23 years working as a building inspector I'v seen way too many structural problems caused by inadaquate beam installations, Its worth the time and money to do it right.
Good Luck.
Nov 09, 2009 | Measuring Tools & Sensors
Low beam head lights are dim only have 5.9 volts at head lights high beams work fine have 11.8 volts to them.
Sounds like a bad ground. Using a test light, figure out which of the wires going to the bulb is a ground and try re-grounding each bulb. If that fixes it, chase the wire and see if you can find the break. There may also be something else drawing on that line as well. Be careful with this because you could blow the bulb or do some harm if there is some thing also drawing juice. Be prepared to unhook the test ground. If you have daytime running lights, see if that's still pulling on the power when you switch to regular lighting. Hint: daytime running lights go off when the parking brake is applied.
Aug 02, 2009 | 1996 Chevrolet Blazer
Streaks between oven door
I have the same problem.... any resolution??
Jul 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
Sc 322 on a 3045. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont...
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Oct 16, 2008 | Ricoh Aficio 1035 Copier
My 48-inch Viking gas range is making a high-pitched, continuous, whining noise (not a beeping). It has never done this before.
Anyone figure out what the fix for this is??? I just bought a new frigidaire and it's doing the exact same thing!
Mar 16, 2008 | Kitchen Ranges
Punch Professional Home Design Platinum Suite (26635) Logo
657 people viewed this question
Top Punch Computers & Internet Experts
k24674
Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
