Question about Intel Play QX3 Monocular Microscope
I have installed the intel play shourtcut and i have the microscope i have also plugged the USB cord in but when i get to the main screen it says The Microscope is not responding please reboot the computer (77). please help me
  • 72 Answers
SOURCE: have QX3+ driver for my intel play microscope but poses a problem
Uninstall the existing Intel microscope software and then follow the following instructions:
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on May 24, 2009
bluegreenash
  • 661 Answers
SOURCE: Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
Posted on Sep 15, 2007
SOURCE: Intel Play QX3+ Microscope
Try a different computer and install the QX3Plus application (for Win 2K-XP). If it works okay, then completely remove (uninstall) it from your Dell 4600 and clean up the registry of unusable strings (try Advanced Registry Optimizer, its a free download). Then do a clean QX3Plus install BEFORE you plug in the USB cable. If the QX3 did not work on a different computer, the QX3 is faulty and maybe you should look at the QX5 as a replacement. The QX3 was discontinued at around the turn of the Century. However, if you are only missing the SPLAT; try locating the green button at the lower left corner of the image screen, it produces drop-down dialog boxes to splat screens. Good Luck!
Posted on Jan 07, 2008
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
SOURCE: I plug the usb cord of the intel microscope to the
I'm not sure but there is a much better program to use with your QX3 called CameraScope, and it's free!. You need to have the QX3 software installed (but not running), it uses the drivers. You can find CameraScope here http://www.teacherlink.org/tools/ The download link is at the bottom of the page. It says it's a beta version but it is the only version they ever made so ignore this. It's an old prog. but is is better than it Intel one. It comes with a separate app that turns on the QX3 light. If you'd like to put a shortcut on your desktop follow the directions below.
  • Just go to "C:\Program Files\CameraScope"
  • Inside you will find QX3Light.exe
  • Right click this, go down to "send to" and select "desktop (create shortcut)
  • Go to your desktop and click QX3 Light... done!
I hope you like this one better, it is much faster loading and doesn't mess with your screen res.
Jessie
Posted on May 03, 2010
I need dowland drivers to intel play model APB 24221 99A
Here are the instruction for installing the QX3 (or QX3+) Microscope with Vista and Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions.
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/QX3-Win7-Files
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Before you run the QX3Plus program right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 5. Now double-click on the QX3+ icon on the desktop and the program should run.
Aug 13, 2014 | Intel Play QX3 Monocular Microscope
I plug the usb cord of the intel microscope to the notebook but the intel microscope is not lighted up. Can anyone assist?
Jessie
Jan 20, 2010 | Intel Play QX3 Monocular Microscope
Have QX3+ driver for my intel play microscope but poses a problem
Mar 23, 2009 | Intel Play QX3 Monocular Microscope
My harddrive opens but wont let me play my music off it
becouse it is not there, u can only se shourtcuts. Try clicking on the files by right click, then propertys and u will see that it is shourtcut.
Jan 21, 2009 | SimpleTech Signature Mini 320GB External...
Vista driver for Intel QX3 Microscope
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Dec 16, 2008 | Intel Play QX3 Monocular Microscope
Need cd rom
You can download the software for Windows 2000 and XP from the Intel support site:
If you have Vista, follow these steps:
Dec 07, 2008 | Intel Play QX3 Monocular Microscope
I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Step 1. Install the QX3+ downloaded from Intel:
Step 2. Download and install the QCODINSTL Codecs software from:
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Dec 17, 2007 | Intel Play QX3 Monocular Microscope
Winxp not detect Intel Play Microscope
If you connect any USB device to a pc, it will be recognised only if there are drivers previously installed for the device. If there is a driver disc with the microscope, install this first or whatever the instructions; if any tell you. Unknown usb device means it has found your device(in this case your microscope), but it doesn't yet know what it is.
Oct 16, 2006 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
362 people viewed this question
Top Intel Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
