Question about Ovens
OB60SCEX3 fan force not heating - Ovens
Fisher and Paykel oven hot heating on fan force
Possibly a burnt out fan element. You or a service person needs to test the element & wiring with a multimeter.
May 10, 2016 | Fisher and Paykel Ovens
My Chef Select fan forced oven has no heat. I have replaced the fan motor and the element, but still no heat. What else could be wrong with it?
Check that it is not been set on automatic. Try turning the timer /clock control through 24hrs and it may go click, fixed
Feb 21, 2013 | Ovens
Fan oven not heating up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
Don't know how will the chef premier fan forced grill work please help thanx neha
The fan radiates the heat to the food to be cooked in the steady heat . when the heat is modest the fan does the convecction well to keep all the areas well heated.
So use only the required heat and the best timing
Sep 11, 2010 | Ovens
Fan forced heat not working
If it is an electrically heated fan oven, then it sounds like the oven element is not working.
This is usually located at the rear rof the oven behind a removeable cover.
Hope this helps.
Dec 05, 2009 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
