Question about Whirlpool Washing Machines
How do i reset the ccu in a whirpool Front loader duet wfu9400su00 with a F28 code?
  • Whirlpool Master
  • 17,970 Answers
F-28 is a serial communication error. either your main cntrl or motor control is going to be bad. hard to say which one without a multi meter and the machine in front of me though.
Posted on Apr 05, 2011
I have a whirlpool duet sport that is displaying F28 code. I have replaced the ccu unit now what do I do. It fills but will not wash, drains but will not spin HELP PLEASE!
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is the CCU to order.
Here is the MCU to order.
Nov 03, 2012 | Whirlpool WFW8300SW
I had a short power outage and then my washer gave an error code of F28 and now I can't get it to work. Please help
F28 is a s error from the CCU to the MCUUnit.
remove the lid and the back of the machine.
CCU is the box at the top front right hand corner.
look for connector M13 with a red mark on it and only 3 wires disconnect it and pull gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
put back together.......
MCU is at back lower left corner.
Find the connector with 3 wires and red mark, pull off this connector , spray it and put it back....should be job done...............
cheers
Apr 11, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Fi pops up on my front load whirpool duet model wfw9200sqoo. and wont finish the cycle. unless we manualyput in rense and spin mode and somtimes unplug it, and reset spin mode,, and somtimes like today...
Frontload failure code
F-1= EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU. Bummer.
DUET SERVICE MANUAL AND MORE HERE
Jan 25, 2011 | Whirlpool Washing Machines
Code f28
Hi, the error code F28 means one or both of these parts are bad.
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 code on whirlpool duet washer. The door locks
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
130 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
