Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
The middle spray arm of my electrolux 4000 series dishwasher fell off. how do i reinstall it?
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Need new spray arm for my dishwasher
Try this link to identify which wash arm you need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5148522
Posted on Jul 21, 2009
SOURCE: I have a frig/electrolux gallery
If you go to searspartsdirect.com and type in 154607802 for the part #, I'm pretty sure that's what you are looking for. I broke the exact same part and it's what my husband ordered as a replacement.
Posted on Dec 11, 2010
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
I have a frig/electrolux gallery series dishwasher: model GLD2445RFC0 serial # TH72896159. On the ceiling of the dishwasher is a gray plastic arm that snap onto a round gray disc that screws into the...
Nov 14, 2010 | Electrolux Dishwashers
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Top rack does not clean, white residue all over dishes, it appears that top does not spin
the white residue is actuially soap
at the risk of a bad rateing
try refilling your jet dry
or dont use those mixed soaps
also check to ensure there is nothing clogging the holes on the spray arm
hope this helps
Oct 24, 2009 | Electrolux Frigidaire Professional Series...
Top spray arm does not rotate, is mechanically
try checking the water holes in the arm, as when they spray out the arm turns. If they are blocked in any way it does not turn, try using a needle to check they are clear.
Aug 07, 2009 | Electrolux Kenmore 24 in. Built-In...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Fridgidaire professional series drain smells and won't clean
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
nmsgjh
Jun 18, 2009 | Electrolux Frigidaire Professional Series...
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Installation of a new top spray arm
should only be a little plastic push in clip facing down towards the dw in the middle of that spray arm. should be able to pop it out. you may need to take the supply tube off the back so you can get a good look at it
Nov 21, 2008 | Dishwashers
Spray tower fell off
The Spray tower fits in the bottom rack, Its actually pretty obvious as there is no way it can sit int he position it has to without being in the rack itself otherwise the rack and tower would block each other all the time.
 Examine the base of your spray tower it should have two "clips" or plastic protusions that will, with a circular twist, snap onto the bars of the middle of the rack itself. Then when in place and your rack is slid inside the dishwasher the tower should sit directly over top of the exact middle of your bottom spray arm.
et Voila.
Nov 09, 2007 | Kenmore 24 in. 16309 Built-in Dishwasher
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
93 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
