Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
Can you please tell me what the input power is for a Miller 250Dx in Australia? I know it has to be three phase but I need to know how many volts and Amps.
  • 407 Answers
Your machine can be plug at different voltages from 220 to 575 V. All you need to do is change the position of the jumper links that are located on the back of the machine near the lead cable connector.
Posted on Sep 27, 2011
Miller deltaweld 652. Turn main switch on and you here a humming sound and the main contactor does not pull in??
Sounds like low voltage to the contactor. Reasons could be wrong input jumper settings for input power. Weak input three phase power. Bad control transformer (supplies power to contactor coil through the power switch). Just need to "dig" with a voltmeter.
Jul 09, 2015 | Miller Welding Tools
Where can i obtain a wiring diagram
A one phase 3 wire system has a center tap. Two hots and a neutral. Typical 120/240 volts.
A three phase 4 wire system has Three hots in a Y or Delta. The Y system has three hots and the neutral comes from the center of the Y, this is the neutral and grounded conductor, 120 volts from hot to ground and 208 volts hot to hot. In a 3 phase system the voltage is not doubled hot to hot as in a single phase system because the hots are 120 degrees phased from each other and the square root of 3 is the factor, multiply the 120 volts by 1.73 to get 208 volts hot to hot. Multiply 208 by the reciprocal of 1.73 and get 120 volts. Your exact application is not given so it is not known. A delta system is a triangle and the angle of each triangle is a hot wire, one angle would be grounded or the center tap of one of the sides of the triangle. Y is the configuration of the windings of the alternator or transformer and Delta is the configuration as a triangle of the windings of the alternator or transformer where the power supply is.
With a three phase home service, you can only connect two hots from your single phase generator, and the neutral. One of the house's hot does not get connected and any three phase loads in the house should be switched off and kept from energyzing or a circuit breaker or fuse serving that 3 phase load may trip.
Only one power supply can be connected at a time. The power company power must not be connected at all while using an alternate power supply unless your power supply has means to synchronize the alternating cycle.
It is adviced that the loads be kept within 10% of their rated voltage, especially motors.
May 04, 2015 | Heating & Cooling
Voltage and breaker sizerequired
I am workshop Officer I brought my 250dx from USA Miller tig welding 250 Dx Solve problems Exit Fine of plant in the Pl detail gauid
Mar 27, 2014 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
1993 KD15 series miller delta weld 300 can it be hooked up to 220 single phase
Theoretically yes, but it would be a great deal of work and would draw a little over 6 times the current it did when on three phase power.
It would entail replacing the fan motors, connecting the 6 windings of the 3 phase primary in phase and in parallel. Plus adding a 115 circuit " tapping off half of the 220 single phase" incoming power for some aspects.
The control board would also need modifications as well. because it uses 3 current sense transformers and you would need to rework that circuit to compensate.
The short answer if you were wanting to set one up for home use- just invest in a "Sidekick" They did have a 240 volt single phase version, and if you consider the time invested to change something over that could trip the 200 amp service breaker, if you value your time- the money for a Sidekick would be well worth it.
If you want proof- open up the primary side of the Deltaweld and look at all of those connections you have before you- you would not be using 1/3 of them, and you would need to take the time to make sure the 6 windings were in phase otherise the transformer burns out- it may burn out anyway because the current draw increase beacause all the low impedance windings are now in parallel on a nominally lower voltage- just the potential of fire from that arrangement makes the money spent for a Sidekick to be considered "cheap insurance."
Mar 29, 2012 | Miller Welding Tools
How to make a miller master 175 from 480v to 208v or a regular house outlet.
You can't convert a 3 phase transformer to single
phase 240 volt
208 volt is strickly 3 phase
May 23, 2011 | Miller Welding Tools
HELLO , i have a Powcon 300 SM i have understood how to change from 460 volt to 230 volt three phase but i can not figure out how to change the whole machine over to single phase 240 ...
Look for a "Phase Converter" at Harbor Freight or look in You Tube for info on building one. If you have a lot of welding to do, I would get a better quality converter than they have at HF.
Nov 29, 2017 | Computers & Internet
Need power input wiring diagram for 230V use
you can get the manual here:
http://www.millerwelds.com/service/locate_om.php
Jul 23, 2010 | Miller Electric Manufacturing Electric...
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
Miller welder serial number KF957066. Please tell me about this machine is it a generator type or three phase? It is in an auction and was wondering about it. Never saw one in my life although I have been...
Miller welders are great. I've been around them a long time as an electrician in the mines years ago. They make a 3 phase model and a motor gen type too. They are both good welders in my opinion.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 19, 2009 | Welding Tools
Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
Looking at the model number, it appears to be a 3 ton. (36,000 btu) Most all residential units are single phase and most all commercial are 3 phase. One way to tell, look to see if the compressor has a capacitor. 3 phase never use capacitors on the compressors as they are not needed. Some residential units have a "Dual" capacitor. That is, it has 3 terminals, 1 common, 1 for condenser fan motor, and 1 for the compressor. Also, this info should be printed on the unit's lable.
Good Luck and hope this helps.
May 09, 2009 | Amana Comfort Zone 12M32PBEH Air...
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
284 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
