Question about Canon T70 35mm SLR Camera
Rewinding the film
I believe i finish taking pictures with the film. Yet the film is not rewinding on its own. What do i do?
The film will not rewind on its own. If you turn the camera over you will see a small slide switch with a small button next to it. Push the button in and slide the switch at the same time, the film should then rewind. Also the camera must be in the on mode.
Posted on Feb 13, 2010
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
I am having trouble unloading my holga 135mm. I finished taking pictures on my roll, and now when rewinding it so that all the film is back in it it just won't do it. Before this happened, when ever I...
This probably means that the film did not wind on to the take-up spool, so no photos were recorded. Check the results when you process it - if its completely blank, that is what has happened.
Aug 11, 2017 | Holga 135BC Film Camera
I just finished taking my film, how do i rewind it so it will not expose the pictures?
Press in the rewind button on the bottom of the camera. Unfold the film rewind crank and turn it in the direction of the arrow. Stop winding after you feel a sudden release of tension, then open the camera back and take out the film cartridge.
If you need a manual, you can download one at
http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
Feb 18, 2011 | Cameras
Hi, I was taking pictures with my camera and I turned the handle to get to the next picture and the button we press to open the shutter (capture the picture) I can push it but it wont click. Please tell me...
Sounds like the shutter has not fully cocked, which often happens when you get to the end of a film and the film advance won't move on a full frame. Try the film rewind crank(gently). If it is not able to turn either way, then you have used up a film and have to rewind it and remove it from the camera. You will then be able to advance the film wind lever to finish cocking the shutter and it will fire as normal.
Oct 18, 2010 | Nikon FE 35mm SLR Camera
How do i know when the film has finished? will it just stop taking, as i think it has come to the end now? it's just stopped and i can't take anymore. i'm just a bit scared to open it in case it ruins the...
The frame counter will read at least the number of frames the film should have. If the camera will no longer 'fire', the film has probably come to an end.
Rewind the film and take it out normally. You'll notice if the film is no completely exposed since the rewind time is relatevily short.
Anyway, it's better to have a few pictures than no pictures at all.
May 21, 2010 | Nikon F3 35mm Film Camera
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
How do you open te Vivtar V4000?
I have used left/right as if you are holding the camera ready to take pictures.
I have included the instructions to rewind the finished film.
!/ Press and hold the film rewind button button on the right side of the camera base.
2/ Fold out the rewind crank top left of camera and turn it in the direction of the arrow.
3/ Once the pressure eases, the film is completely wound into the cassette.
4/ Lift up the film rewind knob top left of camera and pull it out to open the back cover. Now the film cassette can be taken out.
5/ Do this in a place away from direct sunlight.
Jan 05, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Canon T70 35mm SLR Camera Logo
274 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
