Question about Frigidaire Refrigerators
Freezer side will freeze but refidgerator side wont cool
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 05, 2011
My lg refidgerator modle lfx25976st it runs but doesnt cool or freezer wont
Check for a bad hard start cap/relay on compressor. If it is running check for ice on evaporator - if ice then the defrost mechanism is not working.
Aug 27, 2017 | LG Refrigerators
Where is the reset on my refidgerator wont get cold enough kid left it open
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
Refidgerator not cooling
Check compressor working. If yes, keep your arms side of fridge body. If you feel warm, it's o.k. Otherwise, chocked or leak in the system. Call repairman to recharge gas after flushing out system.
Jan 22, 2011 | LG 19.7 Cu. Ft. Side-by-Side Refrigerator...
Frig or freezer is not cooling
Tap on the freezer knob and see if refrig comes on . If so , replace the freezer thermostat ( piece with the knob ) .
Jun 04, 2010 | Frigidaire FRS23KF5C Side by Side...
The freezer seems fine but the other side is not very cool.
I had the same problem w/mine, Found out it was the timer. There is a timer on most fridge's that turn on a defrost lamp inside your fridge. That is why all fridgs are frostless now. They still freeze up, but a lamp will defrost them automaticly. When the coils freeze up, they wont cool the fridge side & but will still cool the freezer side. generally the timer is where the controls are, behind the cover.
Mar 31, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
The freezer is working fine but the refridgerator is not cool enough
Sounds like your frig is not defrosting. Locate defrost timer and start manually. If that solves the problem, replace defrost timer. Another possibility is that the evaporater fan in the freezer compartment is not working. Both items easy to replace.
May 10, 2009 | Refrigerators
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
82 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
