Question about Frigidaire Freezers
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 05, 2011
Ice machine keeps freezing on the ice trays
If you are referring to the ice not clearing the evaporator plates, usually the defrost cycle is too short. Check that by watching the machine and when it goes into the harvest mode, see if all the ice comes off. If not, lengthen the cycle.
May 15, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Major Appliance
It sounds like the thermostat is not sensing when the fridge/freezer reaches it's set temperature.This will result in the compressor running non-stop and this causes ice build-up inside the fridge.See on what number (0-7) the thermostat is set on.If it is set on 7,turn it down to 3 and see if it makes a difference.If there is no difference it means that the thermostat is not sensing & switching the compressor off.You will then have to replace the thermostat.
Regards
Andre Nagel
Mar 15, 2010 | Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
214 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
