Question about Koss KS4192 System
What about the KS4102? I need a fuse for it, its a ceramic f8h250?
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
My bass amplifier requires a ceramic fuse T10H250V. Where can I find one exactly like it?
hi,
Fuse breaks when it has succeeded in limiting further damage.
Check for other possible shorted electrical and electronic
components.
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• Measure supply voltages,
• Check DC offset voltage
• Check idling current (main amp)
Isolate , and trace afterwards.
Aug 22, 2012 | Behringer Audio Players & Recorders
I have a koss ks4102 home theater system, i can not get the tv sound to play through the home system speakers
Source the TV-related audio from the Cable Box,. Treat it like any other audio device.
Mar 14, 2011 | Koss KS4102 System
My remote control for Koss dvd player [KS4102] doesn't work. how can find another remote for the player
1)take the remote & check in electronic market (or)u can get universal remote.
Jun 03, 2010 | Koss KS4102 System
I need to get some ceramic fuses for my big screen tv
Hi josebalbuena
You can buy ceramic fuses from here. They are in most countries of the world. If you could give me more information, exactly what is written on the fuse you require,I could pinpoint the exact one for you. Happy to talk to you further about this.
Regards robotek
Apr 08, 2009 | Philips Televison & Video
42" LCD HD TV keeps blowing fuses.
A ceramic fuse stands up to heat better than a non-ceramic fuse. I'm no pro, but it sounds like your power inverter board maybe bad. There are replacements out there. Good luck
Jan 18, 2009 | Vizio L32 32 in. LCD HDTV
Koss ks4102 pal/ntsc output
try to unplug the system for about 20min to see if it will reset the system
Dec 01, 2008 | Koss KS4102 System
What amp of fuse do I need
There should be a paper tag near the fuse holder, or the fuse holder itself should be marked as to current requirement.
Most older or smaller models used 15A or sometimes 12A ceramic fuses.
Newer or more powerful models use 15A or 20A ceramic fuses.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | Emerson MW8625W Microwave Oven
Koss KS4102 audio delay problem
You can get the update file from here. http://www.kevinschaefer.net/upgrade.zip. Good Luck and let us know how this turns out for you.
Mar 17, 2007 | Koss KS4102 System
Problem with surround working with just the t.v. on
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
Sep 16, 2006 | Koss KS4102 System
Koss KS4192 System Logo
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
