Question about HP LaserJet 1300n Printer
Super efficient printing
Whenever I print to HP1300n printer, all page images get printed onto one page. This is great for paper economy but really really hard to read.
I have uninstalled and re-installed the driver with no luck. Nobody else in the office has this problem. I can print to other printers OK.
Does anyone have any ideas?
  • 200 Answers
Go into the driver and turn of the 2in1 mode.
Posted on Mar 06, 2010
What is the amount of magnetic Powder to be developed in the Fuser Section?
None. It is electrostatic attraction.
It varies from each type of laser printer.
Most printers will specify a total number of pages printed from a laser toner cartridge rather than give an actual amount of toner per page. Which I feel would be more likely to be an average value.
Due to the amount of toner being used per page varying on the number of actual pixels that are required - a black dot or a color dot. If a colour dot is required Three toner colors may be involved to get the color required. Where there is a white dot no toner is required.
It really depends on what image is being rendered onto the paper on each different page image print onto the paper.
Color photos use more toner as more of the page is color than when using black and white !
Jul 02, 2015 | Office Equipment & Supplies
I have an HP1300n and have been using a custom database to print A6 labels for years using the manual feed tray. Recently it has decided to get stuck in portrait mode and whatever and wherever I change the...
What about A4. does it print fine on A4. if it does then paper path is clear , if it only Jams/stucks on portrait mode, what size or media u using. it could be HW fault- where the separtaion pad and paper pick up roller is worn out or it is simply setting issue on the printer drivers. Go to printer driver of the printer- printing preference and check setting from there
May 16, 2014 | HP LaserJet 1300n Printer
Is there anyway to print onto A7 size paper on this printer?
yes-
you can print 2 A7 pages onto 1 A6 page and then manualy cut the page in half- hey presto 2xA7 prints
Dec 11, 2013 | HP Laserjet CM2320nf All-In-One Color...
Printing page going to pause mode
check paper size setting and also auto paper size setting
Jul 28, 2012 | Ricoh Aficio 2232C Color Copier
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
Only printing 1/4 of page
Follow steps below
Load photo paper or plain paper with the print side facing you.
Open the All-In-One Center.
Click the Saved images tab.
From the Creative Tasks section, select Print an album page with various photo sizes.
Click Change the category of layouts listed above.
From the Selected Layouts box, select for example Only Borderless.
Click OK.
Select a paper size for the photos <- use DIN/4 to print on whole page
From the Page Layout area, select a page layout.
Drag the photos onto the page.
Click Printer Settings.
Select the paper size and paper type. <- use DIN/4 to print on whole page
From the Quality menu, select Photo, and click OK.
Click Print Now.
Hope this is helpfull and answers your question.
Aug 31, 2009 | Lexmark X2350 All-In-One InkJet Printer
HP photosmart 7280 - when printing with Toshiba or HP notebooks (both Vista) a blank page is ejected between EACH printed page of a document. HP had no solution.
Assuming that you are connecting directly to the printer via USB, on the advanced tab under the printer properties, make sure the "Print Directly to the Printer" option is selected.
Aug 16, 2008 | Televison & Video
When i print all appears on one page
Try this if you still have the problem. I ran into the same problem on our HP1300n. Once I changed the processor the problem went away. Hope this helps.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1193993
May 23, 2008 | HP LaserJet 1300 Printer
Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP LaserJet 1300n Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
