Question about Dryers
I have a kenmore 70 series dryer and it has been making a metal on metal sound as it turns for the past couple of days. Do I change bearings or rollers or what? It is heating up fine and was working perfectly for the past 6 years.
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Apr 05, 2011
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
What's wrong with my dryer & how do I fix it? Kenmore 70 series dryer won't shut off!! It stops when the door is open but won't shut off on it's own.
If the timer just keeps going past the next off and never shuts off then it could be one of two things. First, is the heating still on when door is opened? If it is then the electric heating element is broken in half and one half is getting neutral by laying against the metal heater case which will cause this problem. (assuming a electric dryer). If not then the timer is the culprit and check fleabay for NOS.
May 01, 2010 | Kenmore 62602 Electric Dryer
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Jan 25, 2009 | Kenmore Dryers
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
We have an electric Kenmore 70 series dryer that is making very loud noises - still drying well otherwise. Husband just took off front and top, and took out drum - still makes same noise when just motor is...
check yopur blower wheel and blower wheel housing...turn with hand to check motor bearing,,if motor bearing tell husband a little bit of wd 40,,or white grease at each end
Dec 28, 2008 | Kenmore 63942 Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
95 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
