Question about Metra 00-2005 Pontiac Montana Radio Install Dash Kit 99-2009
I switched out my radio in my 2000 pontiac montana...hooked up new stereo and it will not work. It work fine in my other car. I tried two radios in the montana and it will not work. everything is hooked up okay, i just dint know if it was the theftlock problem?
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having a problem. The theftlock system does not pertain to anything aftermarket that you do. The theftlock only locks down the factory radio if it is removed, and only if it was activated before it was removed. There was a red led light on the radio. With the vehicle turned off, if the light on the radio flashed, then it was activated. If you hook the factory radio back up then you will have to enter the code to unlock it. Since you used a wire harness adapter, check the red wire and make sure you have 12v current on that line. You didnt state if the radio powers up with no sound or if it doesnt power up at all. If it powers up with no sound, then check to make sure that the blue/white wire is hooked to the blue wire on the adapter harness. Let me know if you are having no sound or no power and I can help you further with this problem.
Posted on Apr 05, 2011
  • conmar70 Jul 19, 2011
    Hi I have the same problem. Stereo turns on but no sound. All the wires look like thr connected.
  • steve_n63630
    steve_n63630 Feb 08, 2014
    I replaced my radio/CD OEM unit with compatible after market model, but it doesn't even turn on. Checked the fuses -- everything looks fine. A bit lost.
I installed a dual Bluetooth stereo system in my 2002 pontiac montana I installed the radio pro 5 I have it all hooked up correctly everything turned on but no sound at all what else could it be?
Depends on the type of OEM radio you had in the system before the replacement. Your car may have an auxiliary amplifier between the radio and the speakers, and if so, you may have to bypass it. In any case, have a look at the original wiring diagram (Alldatadiy.com will probably help) and check your wiring again.
Jul 04, 2017 | 2002 Pontiac Montana
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
Pontiac montana dvd & radio
Being a Brit I don,t know the car but would suggest that your radio/CD might be security coded which works as a security device if someone steals it. There should be instructions somewhere in your glovebox manual telling you how to re-code it. The code would be supplied with the radio and noted somewhere. If not the Pontiac dealer may be able to help you if you quote him your VIN. Some "mechanics" foolishly write the code on the radio unit label - it's stupid but you could try there first!
Jan 30, 2014 | Cars & Trucks
Where can I find electrical schema for the radio of a 2002 pontiac Montana, I want to replace the radio by a Kenwood and I don't know which wires are for the speakers? Thanks for your help. Yves
If you go to your local audio shop, you can get a plug adapter. This will hook up to the back of the new radio, and hook to the cars factory system. You can also order the plug on line. It will save you time and hassle. Also should you ever up grade the system, you don't have to worry about splicing more wiring. hope this helps
Jan 12, 2011 | 2002 Pontiac Montana
Replacement radio anti thieft is locked for 2000 Montana
Contact any GM dealer and they can get you the code and assist you further.
Nov 16, 2009 | 2000 Pontiac Montana
Need radio wiring diagram for 2000 pontiac grand prix factory diagram
2000 Pontiac Grand Prix Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Sep 17, 2009 | 2000 Pontiac Grand Prix
I bought a used radio for my pontiac montana 2001 but it says the radio is locked how do I unlock it?
There is a security code for it, you may have to get it from the dealer or look it up online if its a factory stereo.
Jun 25, 2009 | 2002 Pontiac Montana
Light burned out on radio/clock dial - how to fix?
Sorry there is no quick fix for this problem. If it's the face plate that light's up, there are some electronic shops that can fix it for under the cost of a new after market radio. Just keep in mind there the junk yard has lot's OEM radio's waiting to be bought.
Mar 24, 2009 | 2003 Pontiac Montana
Install new cd player please help
HERE U GO.
2002 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Location: N/A
Feb 05, 2009 | 2002 Pontiac Grand Am
Metra 00-2005 Pontiac Montana Radio Install Dash Kit 99-2009 Logo
1,058 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
