Question about Canon PowerShot A460 Digital Camera
Laptop doesn't acknowledge canon a460 camera when connected
My laptop, (a dell inspiron 1300), could recognize my camera when I first connected it, but since I've installed the software it doesn't acknowledge when it's been connected. Any help would be greatly appreciated!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Nov 15, 2012
SOURCE:
SOURCE: ISO S100 software driver for Vista...
If still not working from camera to computer, then take out the camera's card and insert into a Card Reader.
From the Card Reader, connect that lead to USB of computer. This will open up, if you know which driver is the Card Reader. Once known, just double clicks and the computer will do the rest. Then save then in Drive C or give it a name to a New Folder.
Merry Christmas
Alexander
Posted on Dec 23, 2007
  • 3 Answers
SOURCE: Incompatability with Vista
get rid of vista and get mac osx.
Posted on Mar 20, 2008
SOURCE: Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Posted on May 29, 2009
  • 145 Answers
SOURCE: My computer will not recognize my camera...I
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=12956
If you go here it says that for XP it does not have a driver, it also does not have one for Vista.
It does, however, have drivers for Win 98, so I am assuming that this is an older product and may not be supported by XP. But if you poke around in here you may be able to find a solution, not knowing the age of both products, or the purchase date, thats the best I can recommend.
Hope this helps!!
Jim
Posted on Aug 06, 2009
  • 11967 Answers
SOURCE: Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Posted on Oct 23, 2009
Google com
dell inspiron 1300 does not have built in camera. i guess.
Jul 26, 2014 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
My Dell 1300 Inspiron Notebook will not start up, it gets to two green lights but won't go to Four. I cannot get it to start in Safe mode, it will not recognize the command. It does recognize F2 and F12....
Hi petergreenus,
Have you tried draining the power of your system? Please follow the steps below on how to power drain your computer.
1. Turn off the computer.
2. Unplug the power cable from the outlet and remove the battery.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Press the power button and try to observe the system.
Hope it helps.
Thank you for using FixYa.
Dec 04, 2010 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
May 01, 2010 | Dell Inspiron 1300 Notebook
Installed a new hdd after my dell 1300 kept saying no bootable device and no hdd found now still says no bootable device restore cd wont start ether.
Have you tried accessing the bios and resetting it to factory default settings? Sometimes this will get the laptop to recognize the hdd. Otherwise, it may be either the connection isn't secure, or the bios has become corrupt and you may need to update (flash) the bios
Mar 05, 2010 | Dell Inspiron 1300 Notebook
Canon powershot A460 camera not recognized by
Mar 03, 2009 | Canon PowerShot A460 Digital Camera
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
I nee the drivers for the audio in my laptop(dell inspiron 1300)
Michelita,
Hi! I would like to thank you for this chance at solving a problems. The first problem seems like an easy fix. As for the second one, I would definitely need more information about the router (IE. make and model).
Issue #1
Please download the driver from here. Run the setup and be sure to follow any instructions during setup.
Issue #2
Pending more information.
Take care,
Alexander Kogl aka Chimpster
A Family Thing Consulting
www.afamilything.org
Jan 21, 2009 | Dell Inspiron 1300 Notebook
CANON POWERSHOT A460 IS NOT RECOGNIZED BY COMPUTERS
The first thing I would do is go the the canon website and download and re-install the drivers for it.
Oct 09, 2008 | Canon PowerShot A460 Digital Camera
Canon PowerShot A460 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
