Question about Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White
I have a dual flush corona and there is a stream of water leaking into the bowl. It periodically has to continue to fill when it gets low. I have replaced the round seal inside the tank at the very bottom. However, the leak continues. What do I do next?
    Problem Solver:
  • 8 Answers
There should be a float inside the tank of the toilet. Be sure that when the tank fills that the float is not getting stuck, or not floating all the way up and not sealing the flush valve at the bottom of the tank.
Posted on Apr 05, 2011
My geberit model number 131.028 dual flush won't shut off with water and leaks into the toilet bowl
How old? Who installed? Any warranty? I'd follow that route first.
If not warranty I'd try to get the installer to be interested. Perhaps he will have a "red face" an help out.
Feb 27, 2015 | Geberit 131.028.SJ.1 Black Glass Monolith...
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
We have tiny air bubbles in our brand new Kohler tank. We also have tiny streams of water constantly flowing into bowl. It's super quiet while the tiny streams run in the tank, not making the sound o
watch the mechanism after you flush. If the opening that lets water into the bowl does not close snugly, tiny stream will continuously flow. Make sure it closes properly.
Mar 24, 2014 | Kohler Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Caroma CARAVELLE270ADAW-EL Caravelle Elongated Dual Flush Toilet - White Logo
771 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
