Question about Vector VEC054D MAXX Power Inverter
I have a vector VEC054D 2000 watt inverter and the VEC003 Power Inverter Remote Switch. When powering a microwave oven at 800w indicated, the VEC054D alarms when using the VEC003 remote control. Normal operation occurs when using the VEC054D switch.
5 Suggested Answers
SOURCE: Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Posted on Jul 27, 2009
SOURCE: my vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Posted on Aug 15, 2009
nitrospawn
  • 290 Answers
SOURCE: Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Posted on Feb 27, 2010
tomtij
SOURCE: (Vector 400 Watt sst Power inverter) When I plug
You would need a pure sign wave inverter for any electronic equipment to work at its best, the playstation3 will not work on any other inverter. this only outputs 110v I that it the TV is set at 110v.
Tom from www.automotivetechnical.co.uk
Posted on Feb 03, 2013
I have a 2500 watt cobra inverter and I'm trying to get my 700 watt microwave to work but it keeps poping the breaker and shutting off Not sure why
Instantaneous surge current can trip the breaker. You need to look at the data plate on the oven to see what the actual draw off the mains is. 700 watts of microwave power is NOT the amount of power drawn when it starts. You have the fan motor and the tray rotator motor to deal with when calculating the correct size of inverter to use with it.
Sep 21, 2016 | Microwave Ovens
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
On model mw8626w can i use it in my semi with a 1000 watt inverter?
Take a look at the oven's electric rating information. It should be on the label with the model and serial number, and it will tell you how many amps the oven needs. Power in watts is volts times amps, so a 1000-watt inverter is good for about 8 amps at 120 volts output. Some inverters also use a peak rating, meaning power than can be delivered for a short time. The continuous power may be less than that; you'll need to look at the inverter. As long as the power needed by the oven is within the inverter's ratings then you'll be able to use it. Otherwise you'll need to shop for one with more output power.
Jul 15, 2011 | Emerson MW8626W Microwave Oven
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
Output Voltage Low
test power out- put if good then ur microwave even though showing 600 watts the amp draw might be higher than inverter out
Mar 02, 2010 | Vector VEC053D 1200-Watt Power Inverter
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
Jul 23, 2009 | Black & Decker Electronics - Others
Need small microwave for inverter on houseboat
Look at the rating sticker on the oven and use the AC power rating as your guide. The cooking power of the oven is not important, but the power it needs from the AC supply is. Voltage times current is the supply power needed (watts), and you want an oven that will draw less than the inverter's continuous rating, less any power being used by other appliances.
For instance, a microwave rated for 120 volts AC at 10 amps needs 1200 watts. Your inverter would be OK with this as long as other devices aren't using more than another 1000 watts. You can't use the inverter's peak rating. That's only for brief bursts, like when the microwave first kicks on and draws some extra current.
Any mid-power (600 watts or so) oven should be OK.
Apr 16, 2009 | Emerson MW8627W Microwave Oven
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
Vector VEC054D MAXX Power Inverter Logo
217 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
