Question about Kidco Peapod Plus - Quick Silver
The wire frame seems to be twisted around, and we can't figure out how to get it in the correct orientation. It won't fold properly now, and looks funny when unfolded.
I know this probably isn't helpful, but I had the same problem and couldn't find any info on it anywhere. One of the wire loops was in a funny shape (more oblong than the other side) - I ended up bending it in the opposite direction than it naturally fell, and twisting towards me at the same time. It suddenly flipped around and fell back into the right shape. My kids like to jump on top of it and that must have done the same thing when the frame bent inward from them jumping on it. I know this is vague - it's really hard to explain how I did it, but just wanted to let you know it is possible!
Posted on Sep 20, 2011
  • Johanna O'Hara Feb 03, 2012
    Thank you!! I just had the same problem...my husband tried to fold it without looking at the instructions. This fixed it!
    Thank you! I had the same problem and this fixed it!!
Make photos show with correct orientation on digital photo frame
sir,
Your camera may be having more options of orientation or keystone or resize etc, if it is set to such options the picture results as you said, please try to re set your camera to factory default. then you try the photos effect.
Jan 31, 2016 | Cameras
Why does my digital picture frame rotate some pictures?
The picture orientation can be set manually.
You can download a manual here:
http://resources.kodak.com/support/pdf/en/manuals/urg00863/M820_M1020_frames_exUG_GLB_en.pdf
Check chapter "Changing your frame orientation".
May 07, 2014 | Kodak Easyshare M820 Digital Photo Frame...
Pictures oriented incorrectly
the order and way these photos are stored/retreived is different between units..as long as they get displayed thats all that matters..
Jan 15, 2014 | PixiModo Reflection 15M 15-Inch Digital...
I can't figure out how to re-orient some of my pictures to be right side up on my VistaQuest 8" Digital Photo Frame VQ0801W. I need to rotate some so they aren't on the side.
We use Picasa program to manage our pictures and videos. It's a free program and it works great. It should also help to fix the problem you have. Let me know if it helps!
Dec 27, 2013 | VistaQuest 8" Digital Photo Frame
Slow and tight Sram red Crank
I'm sorry, but if you don't know how to order the correct BB or properly install it you should not be building a bike from scratch, as this is probably the first of many problems you will have. As for YouTube it's not a reliable source of technical info. Try this site: http://www.parktool.com/blog/repair-help
OR Contact the frame seller and find out what BB the frame takes or contact the seller of the BB and ask for assistance.
Jul 28, 2017 | Sram Red
How do i replace an accumulator belt on a Phaser 7760
  1. Open the Front Cover.
  2. Release and move the IBT Cam Lever down.
  3. Open the Right Side Door.
  4. Removing the IBT Belt Assembly
  5. Lift the Accumulator Belt Locking Level and pull the Assembly out to remove.
  6. Use Handle to transport IBT Unit. Protect the IBT Belt Assembly from
  7. On the front, there will be 2 torx screws on a plastic strip. Remove those and the cleaning assembly.
  8. There are 2 spring loaded clips. One on front and one on back that release the spring tension on the roller. You have to press them in and press the locking tabs.
  9. Then go around the frame and remove the screws in order to "fold" the assembly and remove the belt.
  10. Be very careful not to bend the bracket near the bearings or you will have belt tracking faults after replacement.
  11. Be sure you install the belt in the correct direction. There is a silver patch on the belt that must be on the inside of the belt assembly when installing. Look at the old one before removing to determine the orientation of the belt.
Jan 13, 2010 | Xerox Phaser 7760 Laser Printer
Got cables back on correct pins but now pc not lighting up hhd or power switch at the front panel
THe lights have a polarity - they need to be on the correct pins AND the proper orientation. Example, if you have a connector with a red & black wire, flip it around so that the black is where the red is and the red is where the black was.
Oct 20, 2009 | Computers & Internet
Can't get playhut to ''fold up easily''
Here's a website that has folding instructions for many of their products. I don't see one specifically for High School Musical. But they do have a customer service number listed as well.
Hopefully one of these other products will be similiar to yours.
http://www.playhut.com/folding.html
Apr 08, 2009 | Toys
I have a grand marquis 1993 and the car wouldnt start although the batteries r good i was told by a mechanic it is the starter . I need to know can I replace the starter by myself and what do i need to do...
I would always suggest having a mechanic do things first and only try yourself if you think you can do it and you do not have the money for a mechanic that can give you a warranty.
Disconnect the battery cables in order to reduce the possibility of accidentally shocking yourself.
Remove the electrical connections from the side of the starter. There are usually two wires: a positive and a negative wire. Remove the positive wire first, and then remove the negative wire from the starter. You may want to mark the connections with a paint pen to help you correctly reconnect the connectors to their proper terminals. To remove the connections, you'll need to use an open face wrench or socket wrench to remove the bolts.
After both of the electrical connections are removed, you'll need to unbolt the starter from the chassis. Before you remove these bolts, take note of how the starter is oriented. You may want to mark the bolts with paint pens. There are usually only two or three bolts that attach the starter to the vehicle.
Remove the starter. In preparation, look closely at your car and determine what path will be easiest for removing the starter. It might be a tight fit, but you'll need to twist and pull the starter around various engine and frame parts in order to get it out of the car. Some cars may be particularly tight, especially those with front wheel drive. You may have to remove other parts in order to get enough space the pull the starter out. If you do remove engine parts, take care to remember their proper location. Replace bolts into the same place they came from once you pull a piece off. This will help you keep up with all of the pieces.
Once you've pulled the starter out, you can put the new starter in its place. You'll need to put it back in the exact same way you pulled the old starter out. Once you have it in place, put in a bolt just enough to hold the starter in place. Then connect the electrical connections beginning with the ground wire. Once the ground wire is connected, attach the rest of the wiring. Next, install the rest of the bolts holding the starter to the frame. Check to see that all bolts are tight.
Dec 18, 2008 | 1993 Mercury Grand Marquis
Kidco Peapod Plus - Quick Silver Logo
968 people viewed this question
Top Kidco Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Kidco Baby Care Expert? Answer questions, earn points and help others
