When i'm using touchpad to scroll it switches into zooming in or out instead of moving the cursor on the screen. it's very aggravating. i just want to turn the zoom feature off.
  • 8,404 Answers
Good luck with that ... it is a feature that cannot be turned off at least as far as I have had any success doing. I suggest you get a USB Track Ball - that worked for me, particularly when I dint have a place to run the mouse.
Posted on Apr 05, 2011
Tip
Dell Latitude Portable (2008 or newer) has jumpy cursor when typing
The Touchpad driver setup has options to keep the cursor from jumping while typing.
  1. Open the Touchpad Properties
  2. Touchpad Settings
  3. Enable the TouchCheck option, set the slider to minimum. (TouchCheck disabled the touchpad while typing. The Slider adjusts the delay. Minimum is .5 second delay, and each notch and additional .5 second delay)
Other options that may cause user problems are Draglock and Tap to Click under Touchpad Settings, and Scrolling and Zoom Settings of Touchpad Properties.
on Jul 12, 2010 | Computers & Internet
Hp g20 touchpad skips
Reinstall drivers. Did you droped your lappy recently ? Have it checked in service !
Nov 04, 2012 | HP Computers & Internet
Hi, I need help with my acer aspire 5750, the Multi-Touch Touchpad has stopped working. It works as in its moves the cursor on screen but the secondary touch control that controls; Circular-motion...
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
Jul 07, 2011 | Acer Aspire One PC Notebook
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My pc desktop is moving left & right with cursor of mouse
It sounds like you have zoomed in on your screen image, so your screen is showing you only a portion of your desktop. In this situation, you move to a different region of the screen using the mouse cursor, as you describe.
You can zoom back out by holding down the CONTROL key while rolling your mouse's scroll wheel (or scrolling with two fingers on the surface of an Apple Magic Mouse).
May 12, 2010 | Apple iMac 17" Desktop
Scrolling/cursor problmem on Sony Vaio VGN-C140G laptop
Im having a similar problem , have you got it fixed yet? I really need some help the scrolling feature on my Vaio VGN - FZ31S does not work at all and I have tried everything.
Feb 20, 2010 | Sony VAIO Notebook
The roller bar area is not working
It sounds like the touchpad needs replacing. Contact me if you can't get it repaired locally.
Jan 09, 2010 | HP Compaq 236076-001 Touchpad
I can't kill the zoom feature on my Acer Laptop. It is a pain.
Go to Control Panel > Mouse > Device Settings > Settings > Advanced Gestures > Pinch
(or alternatively right-click the Synaptics Pointing Device icon in your taskbar and select Pointing Device Properties)
Untick the box that says 'Enable Pinch'. This will disable the zooming.
Additionally, you might be suffering the same problem as I was which was I had no idea how to use the zoom and that's why I wanted to lock it. Having Google stuck on too-big-to-navigate-properly or too-small-to-read for days at a time prompted me to learn. I've since decided the zoom is useful and I'm keeping the feature enabled.
Here is what Synaptics have to say about the 'pinch' gesture:
The Pinch gesture delivers zooming functionality in many applications. The Pinch gesture can be used to perform the same function as a scroll wheel on standard Windows applications that support CTRL-SCROLL WHEEL zoom functionality.
To perform a pinch gesture, place two fingers on the TouchPad surface. Move them closer together or further apart. To zoom in, place your fingers on the TouchPad surface near to each other and then slide them apart. To zoom out, begin by placing your fingers apart and then moving them closer together.
The best zooming experience results when the finger tips of the two fingers are used for the gesture.
That will hopefully be of assistance if you want to learn how to use the zoom rather than disable it. It took some practice but I can do it now without a problem so can fix windows when I accidentally zoom on them.
Aug 03, 2009 | Acer Aspire One PC Notebook
Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
