Question about Jensen VM9410 Car DVD Player
Jensen AWM970 It will not turn on. Power is going to back of unit. Pushed reset button and checked the fuse.
2 Suggested Answers
  • 586 Answers
SOURCE: vm9424 unit will not power on pressed reset button
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Posted on Sep 06, 2011
Unit randomly turns itself on.
Must be getting power some how when turned off.
Jul 07, 2015 | Jensen Awm970 Am Fm Cd Dvd Wall Mount...
We have a Jensen radio in our rv and it comes on every day at the same time model awm970
Your unit has a built in alarm clock that has apparently been set and turned on. To turn it off, press the Alarm On/Off button located about halfway down on the right side of the control panel.
For instruction on using this unit, you can copy and paste the following URL to your address line in your browser, and then save or print the PDF version of the Owners Manual: http://www.jensenheavyduty.com/downloads/dl/file/id/442/awm970_owners_manual.pdf
Nov 20, 2012 | Televison & Video
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Sep 06, 2011 | Jensen VM9424 Car Video Player
Unit powers up and beeps when buttons are pushed. All the menus work and everything looks alright but there's no music in any mode. Hit reset and checked wiring and fuse on back of unit. Any ideas?
if you have power it wouldn't be a fuse. if there is no audio, it could be a bad speaker (or more) causing the problem. a bad or shorted speaker can cause the radio's amp to overload and shut down. use an ohm meter to check the speakers and the wiring. above 4 ohms is a good number. below2 could cause problems.
May 10, 2011 | Jensen MSR4050G CD Player
Hi, I have a Konica Bizhub C451. There is a trouble code C-3824.Any advice to resolve the issue? Thanks Chris
Chris,
Turn off main power inside front cover insure that the sub power switch is pushed in on right side of the control panel. Hold down the Utility/counter button and turn on the machine hold down until screen shows trouble reset touch trouble reset go OK. Power off then wait 10 seconds power on. If the code comes back do not attempt another reset you are resetting the code for the fusing unit (The hot Part) It can catch on fire and that would ruin a perfectly good day! Have a technician look at it Good chance fusing unit needs replacing
Nov 03, 2010 | Konica Office Equipment & Supplies
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9410 Car DVD Player Logo
475 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
