Question about Dryers
I need a wiring schamatis - Dryers
    Problem Solver:
  • 18 Answers
Online
Posted on Apr 05, 2011
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
Have a kenwood stero ,putting it in a 97 chevy lumia,i need the color codes for the wireing horness.
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black/White
Radio Illumination Wire: Gray/Black
Radio Dimmer Wire: Brown/White
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 30, 2011 | Car Audio & Video
Alternator on montero melted the wire and almost welded itself to the alternator i need to re wire the alternator and need to know what all wires i need to check and replace i need this fixed asap for it...
WHAT COLOR WIRES MELT TO ALTERNATOR ONE WHITE WIRE BATTERY FEED FUSE LINK WIRE OR THE WHITE AND BLUE WIRE TO VOLTAGE REGULATOR TO COMBINATION METER. WHEN YOU REPLACE ELECTRICAL WIRES BESURE TO PUT FLEXIBLE CONDUIT AROUND WIRES TO KEEP ENGINE HEAT AWAY FROM WIRES AND CONDUIT WILL KEEP WIRES FROM RUBBING CAUSING SHORT TO GROUND.
Jul 27, 2011 | 1999 Mitsubishi Montero Sport
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
I need the wiring diagram for installing a trailer plug for my 1998 chevy silverado
sammy tatz,
There usually is not a diagram for this type of wiring, as it's wired directly into the current wires. You simply need to follow the wires on the truck (if doing the plug here) and run the wiring to these as needed per light.
If you are wiring the trailor - the new wiring harness should be color coded as well as labeled (if new) for each light. Trace the wires (if attached still) and attach each wire as necessary to it's appropriate light.
I have never personally heard of wiring diagrams for this, at least not for aftermarket wiring. Any other diagrams for wiring can be found in a service manual for your truck.
Please let me know if you need further assistance with this matter.
carsandcomps,
Guru, Premium Expert @Fixya.com
Apr 25, 2010 | 1999 Chevrolet Silverado 1500
Wiring 4 flood lights on a 97 wrangler
you will need:
wire
inline fuse 5 or 10 amp
toggle switch.
you will need to run the lights where you desire. you will need to take one wire this will be the ground. you will need to find a ground for the wire close to the last light you will be connecting.
once you have found the ground connect the wire to it. usually to the frame of the vehicle. than take the remainder of the wire and connect the ground on each light. You can do this by taking the wire and running straight across the lights. you will need to bear a small part of the wire so you can wrap the wire that is coming out of the light to the ground.
once you have completed that you will need to connect the ground wire to the toggle switch.
now you are ready to run the hot. take the second wire and put the end of it on the last light farthest from the switch. and connect the wire from the light to the hot wire. than string it across the other lights. you will need to bear a small opening in the wire at each light like you have done for the ground. you will need to connect the lights together on the hot wire.
now once this has been done. take the end of the wire and find your fuse box. find your light fuse. take the fuse out of the socket. you will need to bear the hot wire and wrap it around one of the slats on the fuse. than take the remainder of the wire and connect it to your toggle switch.
you should be good to go when this has been completed.
Aug 19, 2008 | 1997 Jeep Wrangler
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Dryers Logo
26 people viewed this question
Top Dryers Experts
