Question about Amprobe Amb-25 Digital Megohmmeter Amb25
Have bought 3 x amb-25 units and all have failed in the resistance check, now whatever resitance is put between the probes they read 0 ohms, it is particularly concerning when monitoring in slab heating cables at concrete pour a the resistannce reads 0!!. I have sent 1 back to Fluke and they have said there is nothing wrong.
Your cable is shorted in the concrete. Plus you shouldn't send your amprobe back to fluke.
Posted on Nov 09, 2011
  • Marin Pesa
    Marin Pesa Jan 31, 2014
    Why shouldn't he send his Amprobe to Fluke? Fluke owns Amprobe. His short issue is another matter...
Error code ch n ch2 lg air con
Indoor inlet pipe sensor. Cause of error, Open/short, Solder poorly, internal circuit error.
Check point & Normal condition, Normal resistor 5 ohm at 25 C unplugged.
Normal Voltage: 2.5 vdc/ at 25 C ( plugged in )
Check Point:
1. Unplug the sensor on the indoor unit PCB.
2. Estimate the resistance of the sensor.
3. If the resistance of the sensor is 10 ohms/ 5 ohms at 25 C then the sensor is normal.
4. If the resistance of the sensor is - 0 - ohms then replace the sensor.
5. Plug the sensor on the PCB and Power on.
6. check voltage.
7. If voltage of sensor is 2.5 VDC at 25 C then the sensor is normal.
8. If the resistance is O or 5 Vdc replace the PCB.
Apr 02, 2015 | LG Heating & Cooling
I have a Hunter 60" Grand Lodge Ceiling Fan (23529) My light works but the fan will not.
A quick check to do, is disconnect the power going to the fan (switch off power board) only do this if your a qualified electrician.
Check for volatge AC on the live and neutral wires first then,
After that take out the wires of the fan should be live and neutral.
And check there resistance with a
multimeter. Should be 80-200R (ohms)
If it doesn't read make sure you have plugged your probes in your meter and touch them together to see if they are 0hms. Then check for reading again.
If there is no reading make sure you have correct wire.
If no reading again it means the fan is dead. The windings have open circuit.
To check the switch working. (Remember power is off) put probes across switch and see ohms. Should be either 0 ohms or no reading. 0 ohms showing it's in on position and no reading shows off position. If both readings are no readings then the switch is dead.
To get to the switch you have to open it physically
Jan 12, 2015 | Hunter Dryers
Fuel gauge is inoperative
Check for 12 volts at the orange wire on the fuel gauge. If missing check instrument fuse and associated wiring. If present do the following checks:
1. Remove gauge. Ground Y/W wire of fuel gauge sender located at bottom of gauge. Turn ignition switch ON.
a. Fuel gauge must indicate FULL. If gauge indicated FULL, gauge is functioning correctly and go to step 2.
b. If gauge did not indicate FULL, proceed to step 3.
2. Set MULTI-METER to resistance scale to measure the resistance of the sending unit. Place one probe on Y/W and the other probe on a good ground.
a. If fuel tank is full, the reading should be 40 ohms. An empty tank should have a 240 ohm resistance. A half full tank will be pproximately 97-118 ohms.
b. If a very high resistance or infinity is indicated on the meter, the sender may be "open" or not grounded. Check that sender and fuel tank are grounded by placing one probe of Multi-Meter on sender ****** and the other probe on crankcase. Meter must indicate one ohm or less. Replace sender if one ohm or less was present. If a higher resistance is present, check for poor connection on ground wire.
Sep 11, 2014 | 2001 Harley Davidson FXDWG Dyna Wide Glide
I have a 07 flhx and the fuel gauge reads full all time
When the ignition switch is ON the fuel gauge is connected to 12 VDC, current flows through the gauge and the variable resistor in the fuel gauge sending unit to ground. The sending unit float controls the amount of resistance in the variable resistor. Malfunctioning fuel gauges may be the result of a fuel gauge sender or a fuel gauge not being properly grounded OR there may be a defect in the fuel gauge sender or in the fuel gauge itself OR there may be an open circuit caused by a loose or disconnected connection or a broken wire between the ignition switch to the fuel gauge.
A suspect fuel gauge system can be tested by FIRST removing the gauge and grounding the Y/W wire of the fuel gauge sender located at the bottom of the gauge, turning the ignition switch ON at which point the fuel gauge must indicate FULL. And if it does so then the fuel gauge is functioning correctly.And if it does not read FULL then get a multimeter set to the RX1 scale and measure the resistance of the sending unit by placing one of the meter probes on the Y/W wire and the other probe on a good ground. THEN for FLHT/C/U, FLTR if thefuel tank is full the meter reading should be 7-14 ohms and if the tank is empty the meter resistance reading should be 74-95 ohms resistance and a half full tank meter resistance reading will be approximately 30-38 ohms. For FLHR/C/S if the fuel tank isfull, the meter resistance reading should be 27-40 ohms, if the tank is empty 240-264 ohms and if half full approximately 97-118 ohms. FOR ALL MODELS if there is a very highmeter resistance or infinity reading the sender may be "open" or not grounded. In this case check to see if the sender and fuel tank are grounded by placing one of the ohmmeter probes on the flange of the sender and the other probe on crankcase and if the ground is good the meter must indicate one ohm or less and if the reading is one ohm or less the sender is defective and requires replacement and if a higher resistance reading is obtained you will need to check for a poor ground wire. THENyou can check the voltage to the O/W (+) wire and the BK (-) wire of the fuel gauge connector if the gauge did not indicate FULL and the correct reading will depend on the source voltage and the level of fuel in the tank or the position of the sender float arm on the variable resistor etc. If there is NO battery voltage present there may be a broken, highly corroded or disconnected power wire. If you cannot find a problem using the above testingreplace the gauge itself.
May 10, 2014 | 2006 Harley Davidson FLHX Street Glide
My robin subaru 11hp gen just stopped producing elect
Hi and welcome to FixYa, I am Kelly.
Robin 11 Hp I am guessing here... RGV6100 (Model?)
Things to look for:
1. Open the control panel and inspect the capacitors and the YELLOW wires from the capacitors going to the stator. Look for signs of wax leakage from the long silver 28 MFD capacitors. You would see it in the bottom of the control panel enclosure. Probe the capacitors with a meter on a resistance (ohms) scale of R X 10,000. You should see a huge jump in resistance and then the meter drifts to infinity. Reverse the test leads looking for the same indication.
2. Inspect for any loose connections from the control panel to the stator. Look for dark or hot connections. Repair as needed.
_________________________________________________________________________________
Stator checks
* STATOR
(1) Measure the insulation resistance between
BLUE lead and the core.
(2) Measure the insulation resistance between
WHITE lead and the core.
(3) Measure the insulation resistance between
YELLOW lead and the core.
(4) Measure the insulation resistance between
BROWN lead and the core.
AC Winding
White / Red = 0.2 Ohm
Black / Blue = 0.25 Ohm
Condensor Winding
Yellow / Yellow = 0.58 Ohm
* ROTOR
Measure the insulation across one of the soldered
terminals of the rotor and the core
Then test across the 2 soldered terminals of the rotor.
Resistance = 1.75 Ohm
NOTE 1 :
Because a diode is soldered to the coil ends at
the terminals, resistance may be measured only
when tester probes touche the terminals in one
combination of polarity. Therefore, if no resistance
reading appears, try checking in reverse polarity.
Diode rectifier test (Lovated between the 2 capacitors)
Orange wire should read to all of the other terminals.
Both Brown wires should read to the Brown White wire (Note polarity)
Those are pretty much the checks that you can do and should reveal where the problem lies.
I think you may have a burned wire / terminal somewhere inside the control panel.
Usually when they just stop working the failures are
1. The rotor (Bad and horribly expensive news)
2. Capacitor wires (Yellow) open
3. Stator wires damaged.
The stators on these units do not usually fail.
All manuals for this unit can be found here (Owner's / parts / Service)
http://www.robinamerica.com/productsupport.aspx?pid=28
If the link doesn't work use:
http://www.robinamerica.com Choose Power products and then customer support. Manuals.
This should give you something to work with. Thanks for choosing FixYa,
Kelly
Aug 31, 2011 | Electrical Supplies
Stop produceing power after only 20 of running
Hi and wleome to FixYa, I am Kelly.
Pull off the small cover on the OUTSIDE of the end bell that covers the bearing and the brushes. Using a meter on resistance scale of R X 100 or R x 1000 probe the brushes and see if you read any resistance You should see a reading of much less than 1000 ohms that would be the rotor winding resistance. If you do not have resistance then remove the brushes and check the condition and LENGHT of the brushes. The brushes should be no less than 3/8" long. If you can get your test leads into the brush holes probe the slip rings and read the rotor resistance. You must read resistance under 500 Ohms. No resistance or can not reach the slip rings remove the end bell and test rotor resistance again but probing the 2 slip rings.
Most of the time the brushes wear out or break off when a generator just suddenly stops working.
Reinstall the end bell and read for a DC voltage reading of 3 - 9 volts across the brushes after you know the brushes are in good working order. No voltage then the AVR has failed. If you have voltage then the final tests would be continuity checks of the diode and capacitor in the end bell and finally the stator windings. The dilde will ony read resistance in ONE direction. It should NOT read open or shorted in both directions. The capacitor check use R x 10,000 and probe the capacitor terminals. Reverse the leads and probe it again. You should see a brief jump in resistance and the meter will drift to infinity EACH time you reverse the leads.
If you want parts information I need the model number off of the unit data plate to get that information for you.
Kelly
Aug 25, 2011 | Coleman Powermate Powermate 5000W...
Range controlpad is no working, is showing SA6& each burnershows 56 orS6
Hi and
SA (burners off) is a door lock switch A problem. The switch has to be checked for 0 resistance across the terminals. If it has resistance then there is another resitance check to look ofr 2350 Ohms between pin 5 in plug P4 and terminal N. If the meter reads zero or infinity the lock motor or the wiring to the lock motor is defective. If the meter reads 2350 Ohms replace the electronic oven control.
This is per page 97 of the service manual: (C/P)
http://frigidaireservicetips.com/pdfs/477_5.pdf
Remove power from the range and go to the back of
the control and disconnect the P3 plug. Measure
the resistance between pins 3 and 4. If the meter
reads infinity check the oven door switch and the
wiring to the door switch. If the meter reads zero go
to step 2.
2. Measure the resistance between pins 1 and 3 of
plug P3. If the meter reads infinity switch A of the
lock motor assembly or the wiring to switch A is
defective. If the meter reads zero go to step 3.
3. Measure the resistance between pin 5 in plug P4
Kelly
Nov 24, 2010 | Kenmore Microwave Ovens
My oven is stuck in probe mode and will not cancel.. what should i do
Measure the resistance of the meat probe on the K-ohm setting. If it's open, then the probe is bad. I'm not finding a spec on the resistance but it should be something in the K-ohm range.
Next stop is to check the meat probe socket. May be gunked up with condensed grease or whatever. Sometimes a light schmear is all it takes to flake it out. Then check continuity from each leg of the meat probe socket back to the ERC, where the meat probe harness connects.
Mar 06, 2010 | Ovens
Need diagram for compressor terminals .need to know what is common,start and run terminal
As you are looking at the terminals
The nine 'o clock terminal is the common
The 2 'o clock terminal is the run,
The four 'o clock terminal is the start
http://www.lodgingac.carrier.com/Files/LodgingAC/Global/US-en/52CP_Wiring_Diagrams_52cp-2w.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 18, 2009 | Migali Refrigerators
Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Jun 08, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Amprobe Amb-25 Digital Megohmmeter Amb25 Logo
88 people viewed this question
Top Amprobe Measuring Tools & Sensors Experts
Vuk B
Lawrence Oravetz
Are you an Amprobe Measuring Tool and Sensor Expert? Answer questions, earn points and help others
