Question about Fujitsu 24C1 Air Conditioner
No COOL Air
The compressor seems to only run for a short period of time. Please help.
  • 3,037 Answers
May I ask how you know that the freon level is good. If while it is running, there is not ice cold air coming from it, this would definitely indicate a problem with low pressure freon which would most likely indicate a leak. Only trained professionals are able to check it so unless this has been done, please don't assume that there is plenty of freon if you are doing such a thing. please let me know how you checked it and if it really is fine, then a sensor is bad.
my best to you
Posted on Aug 06, 2008
  • 2,071 Answers
Most new modern A/C units have a built in safety device to disable the compressor if the freon is too low.
hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
  • 319 Answers
A short cycling compressor signals an inadequate freon level in the system.
The freon level should be checked by a HVAC professional.
You also may have a leak in your freon system, as freon does not get consumed during the cooling cycle.
Good Luck
Please respond with comments/more info.
Brian
Posted on Aug 05, 2008
  • Brian Berndt
    Brian Berndt Aug 05, 2008
    Please also check to see if your washable filter is dirty. If it is obstructing the flow of air, it could cause inefficiencies that might cause the compressor to behave as you have mentioned.
    Kind regards
    Brian
Should the fan operate all the time in my refrigerator
Most of the time it runs only when the compressor is running. In other words compressor and fans will run together when the fridge thermostat ask for cold and stops together when thermostat is satisfied. In newer fridges some time inside fan (evaporator fan) might PERIODICALLY run without compressor to circulate little cool air to fridge compartment from freezer compartment.
Sep 30, 2014 | Whirlpool Refrigerators
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
LG 24000btu not blowing cold air. Fan runs but i do not hear the compressor kick on. temps upstairs hit 104 and temp is set at 80. unit is only in use for 2 months. none stop though on cool.
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Sep 04, 2009 | LG Electronic Window Air Conditioner
Our air conditioner does not seem to be blowing any cool air...it basically just seems to be acting like a regular fan
The compressor is probably not runnng. The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Heating & Cooling
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
Ac blows cool than hot seems like a confused system
as it is a general motors product i beleive the relay is right on the compressor. check fuses and any other relays
Robert
Sep 07, 2008 | 2000 Pontiac Sunfire
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
Fujitsu 24C1 Air Conditioner Logo
504 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
