Question about Sylvania G-Netbook
I got this sylvania netbook and so far I have connect to the internet but I don`t have internet? to be a little more specific I have a linksys router , to me awhile to connect to the router but now even connect it according to the notebook still no internet
    Genius:
  • 1,267 Answers
Please try to follow the detail below.
It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on it's backand using a toothpick, insert it into the little hole about an inch diagonallyfrom the right corner of the data plate, this will re-load a new copy ofeverything including the WiFi RT28701 driver. sometimes thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the automatic sign on has not found a viable network, or needssomething else. If I then click on Wireless Information tab, the list ofavailable networks, appear in the box. The machine keeps trying to associate myprevious entered name site with my preferred site and tells me the signal isgood, but it cannot link up. This is a signal to me that it has lost my NetworkKey or that the softwarehas failed or both. I then click on advance and delete my preferred network andhit OK, this will force the software to ask me for my network again, and noticethat the preferred is missing. I click on the name of my network again and thenhit connect., then the Wireless Network properties window opens up and I caninsert my Network Key again after I uncheck the "The key is providedautomatically" box. I enter the key and hit the OK button. I still do notget a connection, so I reboot the machine, and wait for about 30 seconds andthe machine synchs up because the little RED X under the icon has disappeared.Now the machine will hook to the internet as long as I want to, but sometimeswhen I turn the machine on it will not synch, so I go through the abovesequence again. The secret is once you have entered your key and ask for themachine to synch up you have to reboot. Why? I do not exactly know, but Isuspect that the WiFi driver looses it You may also wantto look at the TIP http://www.fixya.com/support/r7679654-sylvania_syneto7526_wirless_keyboard To make your knowledge complete
Posted on Apr 05, 2011
Dns error on sylvania netbook
DNS is Domain Name Server. It translates an IP to a name. Disregard if it is a web site. You have no control.
Most people don't have a static DNS IP or name in the Network Connections > Properties > Internet Protocol (TCP/IP) > Properties. This setting is mostly reserved for larger networks like at work.
Wireless router should be at default and have the same IP as the router. It takes the role of DNS Server.
Oct 06, 2012 | Sylvania G-Netbook
If i reset my router will i lose my netbook connection
You will lose all the settings of your network if you reset Linksys router. If you have active Internet through your router then you will lose the Internet settings. You will need to reconfigure your router from the beginning.
Follow link to setup your Linksys router without CD.
Dec 01, 2011 | Linksys Wireless-G Broadband Router
Have a netbook how to install linksys router wrt120n
Are you trying to install Linksys router?
You don't need to run the CD.
You can do it manually.
Connect your netbook to the router and open the setup page of the router.
Change the settings manually and you are done.
See Linksys router setup
Oct 03, 2011 | Linksys WRT120N Router
Describe your 7" G-Netbook
There may be many reasons for this. Please check the following things one by one.
1. If you have another known good laptop then try it with your wi-fi router. See if the wi-fi router is able to connect to the internet
2. If you don't have another laptop then use an ethernet cable (RJ45) cable to connect to the wi-fi router. See if this helps.
3. While connected with the wi-fi router see if you can access the router. open any internet browser and type 192.168.0.0. you should get the router page. If you don't get then you have to configure the router first.
4. Check the internet settings of your browser. There will be "internet options" or similar in the menu of your browser. Click that. In the GUI you will get "connections" tab. Click that and select the proper wi-fi setup.
Jul 28, 2011 | Sylvania G-Netbook
Sylvania 7" netbook, cannot connect
Try resetting your router- (disconnect the power for 3 minutes)
Feb 06, 2011 | Sylvania G-Netbook
I am able to connect to the wireless router, but I am unable to access the internet. This is a problem with the Sylvania netbook only..i am connected to the internet on another laptop. Please...
The router did not assign an IP address to the netbook ... so first try this
try resetting the router (unplug for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Dec 28, 2010 | Sylvania G-Netbook
I bought the new sylvania 7" laptop. I am having problems.. We have connected to our wireless router however, we not get on the internet...
from another computer, go to the routers configuration screen and make sure the status shows that it is connected to the internet. Also the routers internal LanIP address must be 192.168.1.1 for the netbook to work.
Sep 19, 2010 | Sylvania G-Netbook
I have followed all the instructions on how to connect the wireless router to my Sylvania Netbook and I am still unable to access the internet, can you give me the solution to this problem.
Had the same problem with my Sylvania Netbook I purchased last week. Last night, I stopped by CVS that received a shipment early in the afternoon and purchased another. Powered on to wifi at first and it would not connect on internet. Clicked on little tv, pulled up my preferred connection and entered Network key. Shut down and restarted and it connected onto google!
My original Sylvania Netbook had the same settings in place and still would not connect - so I am returning it today for a refund - it was defective.
Sep 16, 2010 | Sylvania G-Netbook
Sylvania G-Netbook Logo
52 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
