Question about Chicago Pneumatic Air Tools & Compressors
I have a 2hp chicago pheumatic air compressor with burnt up starting capacotor 100kv bolt on one end for mounting,and 2 electical terminals for red and blue wire hookup. Wher can I find one. This comp, is a years old, Thanks for your help.
  • 27 Answers
Hello, You can find one of these capacitors on ebay or at a local Radio Shack type store.
Hope this helps James
Posted on Apr 05, 2011
1995 nissan maxima alternator replacement
1995-98 Models
  1. Disconnect the negative battery terminal.
  2. Remove the splash guard on the right side of the vehicle.
  3. Loosen the alternator belt idler pulley.
  4. Slip the drive belt off the alternator pulley.
  5. Remove the four air conditioning compressor mounting bolts.
  6. Remove the radiator fan and fan shroud.
  7. Move the air conditioning compressor forward.
  8. Disconnect the alternator harness connector.
  9. Remove the alternator mounting bolts, and lower the alternator from the vehicle.
To install:
  1. Hold the alternator in place and install the mounting bolts.
  2. Plug in the alternator harness connector.
  3. Move the air conditioning compressor back into location.
  4. Install the radiator cooling fan and shroud.
  5. Install the air conditioning compressor mounting bolts.
  6. Place the drive belt on the alternator pulley.
  7. Tighten the drive belt to the proper tension with the idler pulley.
  8. Install the splash guard.
  9. Connect the negative battery terminal.
Proper belt tension is important. A belt that is too tight may cause alternator bearing failure; one that is too loose will cause a gradual battery discharge and/or belt slippage, resulting in belt breakage from overheating.
May 31, 2016 | 1995 Nissan Maxima
I'm trying to find the check valve on a chicago pneumatic air compressor model QRS5.0. Can anyone help me with the location.
the check valve is normally on the end of the air line from the compressor into the tank
most are screwed into the tank with the compressor line attached to it.
Jul 12, 2015 | Chicago Pneumatic Air Tools & Compressors
I have aBostitch 2hp air compressor i like to get numbers off the starting capacitor mine got hot and i con;t read it . I call ther sev. and thay woud not give them to me .I whant to buy it localy .w Its
My compressor has a 60uf 330volt run cap with a bolt out the bottom, however, I have seen other values installed. Try using several different values of run caps within this range and select the one that produces the lowest amp draw with good starting torque. Lower voltage cap will also work however will not last long under severe conditions (such as using on generator or long extension cord). The cap does not have to have the mounting bold however do secure to the motor. Good luck
Apr 02, 2013 | Air Tools & Compressors
Looking for a product or instruction manual for a Mongomery Ward 2hp air compressor circa 1970's approx. Has the art.no. xer6468 and serial #12039-215993 printed on the side. This is a 2 cylinder oil...
If you need to tighten belt loosen the motor and slide back until belt taut and should have about 1/2" to 3/4" in deflection. You might try ebay for manual
Jul 29, 2017 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
How to wire it up
if the unit has a starter on it there will be 2 terminals at the top of the starter connect the incoming wires two these terminals making sure that the 2 wires do not touch each other. If unit has only a pressure switch the wires should be tied to the terminals marked line , 1 wire per terminal please.
May 13, 2009 | Ingersoll Rand Air Compressor Maintenance...
How do you remove alternator from 1995 Maxima
Hope this helps!
0900c152800760af.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: The large positive lead connection is protected by a rubber boot
0900c152800760b0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Make sure the alternator ground wire is also removed
0900c152800760b1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Remove the lower adjustment bolt ...
0900c152800760b2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 4: ... followed by the upper pivot bolt. Make sure you support the alternator
0900c152800760b3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 5: Using a C-clamp to push in the pivot bushing will make installation easier
1995-98 Models
To install:
Apr 08, 2009 | 1995 Nissan Maxima
Overheating? burnt oil smell
There is a seal between the compressor and the motor that in failed condition will leak oil into motor windings causing burnt oil smell. Some hitachi compressors suffered from failed valves or head gasket causing extra heat but not oil smell. These compressors also have a thermobreaker built into the windings that when failed will prevent motor from starting or would start and run for only a few moments then open. This part is not replaceable. enjoy
Oct 31, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Coleman air compressor
Should be an electrical diagram on the motor. The motor name plate should also indicate if it is a dual voltage motor. There should be a cover on the end of the motor to access the terminals.
Aug 30, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Open Questions:
Air Tools & Compressors Logo
64 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
