I can't scan documents, - Office Equipment & Supplies
  • 438 Answers
Please do the following.
1. Disconnect the scanner from the computer.
2. From Control Panel->Add Remove Programs, remove this scanner.
3. Reboot.
4. Re-install the scanner drivers from the CD that came with the scanner.
5. Reconnect the scanner.
6. Allow Windows to auto detect the scanner and load its drivers.
7. Scan happily ever after.
Posted on Apr 05, 2011
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
How do i scan a document?
Hi, it all depends on the printer your using.
How to Scan a Document on a Multi-Function Printer
A multi-function printer with a scanner makes backing up your important documents easy. The scanner function of the printer allows you to translate a paper document like a receipt or title deed into an electronic copy that is stored on your computer. Once you have an electronic copy of your document, you can process and manipulate the document as you would any other electronic file. Follow these steps to scan a document on a multi-function printer:
Connect your multi-function printer and computer. Power them up.
Select the side of the document you are going to scan. Give the document a once-over, checking for any flaws that you do not want transferred into electronic form.
Open the printer's lid. Place the side of the document you want scanned face-down on the glass plate of your multi-function printer's scanning bed. Align the document to your satisfaction.
Close the printer's lid carefully. You may want to weigh the document down with another sheet of paper to prevent it from shifting.
Choose an appropriate scan resolution. You may have to do this using the controls of your printer or on the computer, depending on the model and software.
Press the scan button to start the process. This can be done on the printer itself or on the computer.
Preview the scan on your computer monitor. You should be able to make minor changes to the scanned image if needed.
Save the scanned image if you are satisfied with the result. Try again if you are not satisfied.
Tips & Warnings
Scanning documents at high resolution and low data compression will produce the best image quality at the cost of file size.
Not happy with a scan? Re-check the alignment of the document and try it again. Discard the duds when you get a scan that works for you.
Using harsh cleaning chemicals such as acetone or benzene can damage your multi-function printer. Abrasive cleaners are also not good on the machine, particularly the glass surface of the scanning bed.
....How to Scan a Document on an All-in-One Printer?
Scanning is a standard all-in-one printer feature that converts a hard-copy document into electronic information, which your computer can store and modify. You can scan legal files, office reports or just about any other kind of document and create an electronic backup for your files, send it as email or alter it to suit your needs. Follow these steps to scan a document on an all-in-one printer:
Turn on your all-in-one printer and computer. Check the connections between the two machines.
Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
Close the printer's document lid slowly so the document does not shift position.
Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
Push the scan button. You may have to do this on the printer itself or on your computer.
Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
Accept the scan and save. Return the original document to a safe location.
Hope it helps..
Oct 28, 2010 | Office Equipment & Supplies
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
I am trying to scan a document from HP 4280 All-in-One printer HP Solution Center to My Documents. However, I am unable to type Destination (My Documents) in the Scan to. I have reinstalled from the CD...
Generally, the scan to field will designate the the type of program that you want to use to view/edit the document. An example would be microsoft word.
Once you scan the document to a program, you can then save it in any folder on your hard drive, including "My documents". However, if you chose to leave the scan to on "Scan to a File", the scan will automatically go to c://useraccountname/My Documents/my scans.
You can then go to my documents/my scans and move the scanned document to whatever location you would like on your hard drive.
If you have any additional questions about this information, feel free to contact my by replying to this message.
Thank You,
Brian
Jan 28, 2010 | HP Photosmart C4240 All-In-One InkJet...
How do i scan multiple pages
Please perform the steps given below to scan multiple pages to a single PDF file.
NOTE: Before performing the steps please make sure that Adobe Reader is installed on your computer. If not installed then goto www.adobe.com and install Adobe Reader.
  1. Open HP Solution Center.
  2. Click on Settings.
  3. Click on Scan Settings.
  4. Click on Scan Preferences and Select the option 'Prompt for additional scans when preview is turned off'.
  5. Click on OK to apply changes.
  6. Now Click on Home and click on scan Document
  7. Select Document to File under scan shortcuts.
  8. Uncheck the option Preview Scan at right bottom of the scan window.
  9. Now Click on scan to scan document.
  10. When prompted for additional scan place the another document on scanner glass or ADF and Click on Scan.
  11. After scanning is complete Click on Finish to save the scanned document
  12. To Locate the scanned document (PDF) goto My Documents folder and Open My scans folder.
Oct 12, 2009 | HP Officejet 6500 Wireless All-in-One...
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Jan 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
The Scan Settings dialog box allows you to specify advanced settings for scanning.
Document Type
Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
Document Size
Select the size of document to be scanned.
Auto Detect: Detects document size automatically.
Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
Reference See the section below for details.
Scanning images Larger than the Platen (Stitch Assist)
When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
If not, some images may not be scanned at the correct positions and sizes.
You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
Select the resolution at which to scan documents. The following scanning resolution can be specified:
Text(OCR): 300dpi, 400dpi
Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
this should answer your question , feel free to post here agian if you need more help.
Regards, and thank you for using fixya.
Oct 23, 2008 | Computers & Internet
Cannot edit scanned document
its like this, the OCR or the SOftware installed in your computer is limited. If you're trying to scan a document which has a picture or with text that uses different fonts like monotype, or those that are not usually being use for normal documents, usually it wouldnt detect and it become distorted. Anyways, here are the steps that i want you to follow.
1. Open solution center. (click start, go to all programs, go to HP, then click on SOLUTION CENTER). or you can see SOlution Center on your Desktop.
2. Click on Scan Documents, then the Scan documents setting will open. Change the settings to these.
* SCAN TO: Microsoft Word.
3. Then, hit scan.
4. After scanning, the folder My Scans will open automatically, just go ahead and open the scanned document.
5. From there, you can start editing the text.
..remember, the scan a document is limited, it will not read all types of fonts. if the document is using a "times new roman" or "arial" the scanned document appears to be almost the same with the original. But, if the scanned document contains pictures or stylish fonts, that would make the document distorted.
Please let me know if you still have clarifications.
Thank you.
adonscott
May 01, 2008 | HP Officejet 5610 All-In-One InkJet...
jasbo
jasbo
